Yayo Posted March 15, 2011 Share Posted March 15, 2011 I have a rough idle and boost, and just picked up a CEL code P0171. I checked for vacuum leaks and cleaned out my MAF. So i'm wondering if it's my O2 sensor. I'm new to data logging so was hoping someone can take a look at this. http://i745.photobucket.com/albums/xx100/mrdiegov/LearningView_SS_3-15-201162345PM.jpg Link to comment Share on other sites More sharing options...
rao Posted March 15, 2011 Share Posted March 15, 2011 The code tripped because the adjustment is out of range, over 20%. You have an intake leak or a bad o2 sensor. The surprising thing is that you don't have any knock learning. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Yayo Posted March 15, 2011 Author Share Posted March 15, 2011 Thanks rao, yea I'm happy it's not knocking. I'm going to thoroughly check for a leak, but worstcase scenario if it doe wind up being the O2 sensor, which one exactly should I be ordering? Link to comment Share on other sites More sharing options...
Spec B Posted March 16, 2011 Share Posted March 16, 2011 I would guess it's a leak, not the sensor. The afr corrections look fine at anything above idle... Link to comment Share on other sites More sharing options...
rtbrjason Posted March 16, 2011 Share Posted March 16, 2011 Agreed on the leak. Have you recently replaced your filter? Make sure the box is lined up correctly or it won't seal the filter and could cause what you're seeing. This is assuming you have the stock intake in place. Link to comment Share on other sites More sharing options...
Yayo Posted March 16, 2011 Author Share Posted March 16, 2011 I have an AVO intake. Rough idle just started out of nowhere, no mods were added. I wonder if a hose just popped off on its own...hmm I thought I double checked everything. Possibly intercooler piping? Link to comment Share on other sites More sharing options...
NSFW Posted March 16, 2011 Share Posted March 16, 2011 I'm guessing it's a vacuum leak. Check all of the hoses under the hood, look for one that isn't connected at one end, then look for what it's supposed to be connected to. Link to comment Share on other sites More sharing options...
Yayo Posted March 18, 2011 Author Share Posted March 18, 2011 Thank you gentlemen. Apparetly I've overlooked behind the alternator, a very small rubber hose had come off, car is back to normal. Link to comment Share on other sites More sharing options...
NSFW Posted March 18, 2011 Share Posted March 18, 2011 Cool, glad to hear it! Link to comment Share on other sites More sharing options...
wpmarky Posted March 25, 2011 Share Posted March 25, 2011 Yayo, can you post a pic of the hose that you fixed? I also am getting 171, and my Lv looks similar to yours. I've checked the hoses around the turbo and behind the IM, and everything appears to still be zip tied down. Not sure if there are any other hoses I haven't checked yet. Link to comment Share on other sites More sharing options...
keithk831 Posted March 27, 2011 Share Posted March 27, 2011 Yayo, can you post a pic of the hose that you fixed? I also am getting 171, and my Lv looks similar to yours. I've checked the hoses around the turbo and behind the IM, and everything appears to still be zip tied down. Not sure if there are any other hoses I haven't checked yet. My vacuum leak a while back was the turbo inlet hose. It was so corroded I had to replace it. Hard to see it was leaking but when I poked it with a screwdriver and felt how soft it was, I knew... Link to comment Share on other sites More sharing options...
Yayo Posted March 28, 2011 Author Share Posted March 28, 2011 This is the hose that was loose, I just used some needle-nose pliers and was good to go. The CEL light didn't immediately go away so I just cleared the code with my CEL Reader. Good luck man. http://i745.photobucket.com/albums/xx100/mrdiegov/photo-3.jpg Link to comment Share on other sites More sharing options...
wpmarky Posted March 28, 2011 Share Posted March 28, 2011 Thanks guys, During my stage 3 install, i put in a new perrin turbo inlet, so I don't think that's a problem. All the hoses are still on their associated port. I also remember checking that hose in your pic Yayo, pretty sure mine is on there but i'll check again to make sure. Link to comment Share on other sites More sharing options...
