Suby Emi Posted March 6, 2011 Share Posted March 6, 2011 My mechanic replaced the timing belt/water pump on my 1996 Legacy Outback - 170K mileage - 2.5L engine - a few weeks ago. Prior to this my car was running just fine, no problems. I noticed after picking it up that the car had a rattle under the hood that sounded like a tin can. They had put a screw in the wrong place. Fixed that. When I drove my car away from the shop, it started "missing" badly. Mechanic had driven it before I picked it up and it was running perfectly. Took it back and they still can't figure out the problem. At first it showed a code for cylinder 4 misfire. They replaced the spark plug and did some other things. They also looked at the timing belt again to make sure all the hash marks lined up correctly, etc etc. Bottom line is that today there is NO CODE showing, but the engine is still not running smoothly and isn't driveable. Mechanic says he is going to do a few more things tomorrow. By the way, this is a mechanic I've used for 7 years and he is very good and reliable. Very customer oriented, so he isn't a problem for me. His shop has done a ton - and I do mean a ton! - of work on two of my cars, including a Camry timing belt. He says if they aren't able to diagnose and repair, there is a Suby mechanic across the street and he can take a look. Does anyone have any idea what's going on with my car? Link to comment Share on other sites More sharing options...
98LGTLover Posted March 7, 2011 Share Posted March 7, 2011 Mods, can you move this over into the 2nd Gen Legacy forums? Not many people come into this section and I'm sure Suby would be able to get more help there. Link to comment Share on other sites More sharing options...
jamal Posted March 9, 2011 Share Posted March 9, 2011 The timing belt is very obviously not on right. Link to comment Share on other sites More sharing options...
citka Posted March 9, 2011 Share Posted March 9, 2011 ^^ What he said. +1 Link to comment Share on other sites More sharing options...
ebondragon87 Posted March 10, 2011 Share Posted March 10, 2011 Double check timing, some of the older motors are deceitful. If its good then the crank position sensor would be a good place to start diag also. Link to comment Share on other sites More sharing options...
Suby Emi Posted March 10, 2011 Author Share Posted March 10, 2011 Status report....after my mechanic spent untold hours troubleshooting, here is what they found: the timing belt kit had several problems with both with the belt itself and also the tensioner. They put a new kit on and it's fine. Mechanic says that the manufacturer will reimburse him, including labor, which I'm so glad to hear because he spent his time on both a Sat. and a Sun. My sweet Suby runs like the Princess she is now. Thanks for everyone who posted here. I really appreciate it. Link to comment Share on other sites More sharing options...
Thedecieved1 Posted March 10, 2011 Share Posted March 10, 2011 i recently did my own timing belt. i had a similar problem caused by my left cam gear moving off center by one tooth. glad to hear your problem has been solved. Link to comment Share on other sites More sharing options...
