dbrunone Posted March 1, 2011 Share Posted March 1, 2011 So I'm looking at doing a turbo swap (not sure which one) at some point. I'm already stg2 with a dyno tune by Dave Brown at MSPT. My question is, if I install the turbo at my place, how can I safetly drive it a few hours to a dyno tuner to get it tuned? Is there a zero-boost map or something I can use? I have a Cobb AP. Thanks for any help Link to comment Share on other sites More sharing options...
TRSCobra Posted March 1, 2011 Share Posted March 1, 2011 Call your tuner, give him your mods list and see if he can send you a safe map to drive to him with. I had a 3 hour drive to my tuner and that's what they did. Free of charge, too. Link to comment Share on other sites More sharing options...
Spec B Posted March 1, 2011 Share Posted March 1, 2011 If you are just doing the turbo (not injectors or anything else), you will be fine with a 0 WG map and you stay out of boost. Link to comment Share on other sites More sharing options...
BAC5.2 Posted March 1, 2011 Share Posted March 1, 2011 Or just drive in closed-loop while you get there. No big deal. You can hit a little boost without really doing much damage. At low boost levels, regardless of the turbo, you'll flow the same mass of air (compared to a slightly higher boost level on the old turbo). It's fine to get you to the tuner. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
dbrunone Posted March 1, 2011 Author Share Posted March 1, 2011 What about if I swap injectors too? I guess that would need a "safe" map like TRSCobra was saying? Link to comment Share on other sites More sharing options...
rao Posted March 1, 2011 Share Posted March 1, 2011 If you change injectors you need to change the map - the car will not drive (or will barely drive depending on how large of injectors you go with). Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Spec B Posted March 1, 2011 Share Posted March 1, 2011 ^+1 You will need a limp map. Link to comment Share on other sites More sharing options...
rice_rocket Posted March 1, 2011 Share Posted March 1, 2011 Or.. just put the injectors in when you get there A new turbo isn't going to do any harm until you put boost into it past the level that the injectors can handle. There's certainly no harm in taking it easy and driving in the right lane. All cars will be the same at zero to no boost... if you go to a big big turbo, however... something small like 10psi will push a LOT more air and that's no good.. but I'm sure you'd be smart enough to keep your eye on the boost gauge and not drive like an idiot. Since you have a cobb AP you won't be able to load the map would you? I am not sure what year that the accesstuner will let you load your own since I've always done my own. Link to comment Share on other sites More sharing options...
NSFW Posted March 2, 2011 Share Posted March 2, 2011 You'd be surprised... My ATP 3076 makes 10-11psi with boost control disabled, and it moves less air than the stock turbo did at stage 2. At redline they were almost equal (240 g/s vs 245 g/s with stage 2) but everywhere else it was moving much less air and making noticeably less power. Anyway, I agree with getting a 'limp' map from your tuner. It'll be fine for the drive to the shop, and I've never heard of anyone being charged extra for that. It's probably exactly the same tune that he's flash first if you brought the car there on a flatbed anyway. Link to comment Share on other sites More sharing options...
