PaulieKeyboard Posted January 28, 2011 Share Posted January 28, 2011 So I put in a newer EJ25D engine (without bent valves) in my BD LGT and in the process I replaced both engine mounts with the Group N mounts from RalliSpec Now I put them on the plates right and 99.9999999% sure I put the plates on the engine right, but for the life of me I can't get the engine to sit on the crossmember properly ....There are two little tabs on the cross member that I am pretty sure the mounts are supposed to sit in between, but I can't get both to sit between the tabs, either one sits properly and the other will sit ontop of the tab, or vice versa...even tried using a pry bar to nudge the engine off of the tab, but thats not working either....so any tips or suggestions here would really be great and save me from going bald by pulling my hair out Link to comment Share on other sites More sharing options...
Underdog Posted January 28, 2011 Share Posted January 28, 2011 Check here: http://legacygt.com/forums/showpost.php?p=2756300&postcount=482 The Crimson Dynamo Link to comment Share on other sites More sharing options...
PaulieKeyboard Posted January 28, 2011 Author Share Posted January 28, 2011 oh BTW I'm using my engine hoist to raise and lower the engine onto the cross member, would a floor jack from under the engine be a better idea? Link to comment Share on other sites More sharing options...
Underdog Posted January 28, 2011 Share Posted January 28, 2011 Hoist works fine. The Crimson Dynamo Link to comment Share on other sites More sharing options...
PaulieKeyboard Posted January 28, 2011 Author Share Posted January 28, 2011 yup...just checked...both installed properly....i guess its just being difficult.... Link to comment Share on other sites More sharing options...
PaulieKeyboard Posted January 28, 2011 Author Share Posted January 28, 2011 http://img.photobucket.com/albums/v512/JediKGB/Subaru/861ef51a.jpg Passenger side http://img.photobucket.com/albums/v512/JediKGB/Subaru/c222d739.jpg Drivers side Any suggestions? Link to comment Share on other sites More sharing options...
Underdog Posted January 28, 2011 Share Posted January 28, 2011 Tough to tell from the pic as I'm not familiar with earlier gen Legacies, but the white dots are facing toward the front correct? The Crimson Dynamo Link to comment Share on other sites More sharing options...
PaulieKeyboard Posted January 28, 2011 Author Share Posted January 28, 2011 yup..... Link to comment Share on other sites More sharing options...
PaulieKeyboard Posted January 28, 2011 Author Share Posted January 28, 2011 got it....used a floor jack and a pry bar to hold the angle while my wife lowered the engine Link to comment Share on other sites More sharing options...
Underdog Posted January 28, 2011 Share Posted January 28, 2011 Good work! The Crimson Dynamo Link to comment Share on other sites More sharing options...
