sealoss Posted January 27, 2011 Share Posted January 27, 2011 i hve an 98 legacy gt limited and the gear shifts have been getting rougher and all the fluids are fine, what can i do to smooth my gear shifts? Link to comment Share on other sites More sharing options...
subikid90 Posted January 27, 2011 Share Posted January 27, 2011 Auto right? You can try trans-x, some say it has helped a bit, but your tranny is holding on by its last limb. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Baddog Posted January 27, 2011 Share Posted January 27, 2011 Try and give it a new fluid change. See if that helps. Link to comment Share on other sites More sharing options...
98LGTLover Posted January 27, 2011 Share Posted January 27, 2011 Try trans-x first, my tranny got like that and I just had to replace it. Link to comment Share on other sites More sharing options...
kaz98gt Posted January 27, 2011 Share Posted January 27, 2011 Trans-x will work, but I think you need to do a few cycles of it through the system. So, you're looking at 3 flushes and fills of tranny fluid + trans-x every 1000k miles, then top it off with a fresh set of fluid. I noticed an improvement with mine, but I didn't capitalize on it and keep on flushing the fluid/adding in more trans-x when I had the chance. If you don't have the time/patience/money to do the process at least 2-3 times, it's not worth trying the trans-x. Link to comment Share on other sites More sharing options...
