Baddog Posted January 19, 2011 Share Posted January 19, 2011 Well I decided to just go ahead with my engine build. This is my current list for when I go to do the camshafts. Any other suggestions? Also I put in headgaskets on because don't the heads have to come off? Camshaft Seals - $11 - http://www.oreillyauto.com/site/c/detail/FEL0/TCS45918.oap?keyword=cam+seals&pt=02344&ppt=C0026 Timing Belt Kit - $138 - http://cgi.ebay.com/ebaymotors/1990-1996-Subaru-Legacy-Impreza-2-2-Timing-Belt-Kit-_W0QQcmdZViewItemQQhashZitem5641a0bca6QQitemZ370468240550QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Head Gaskets - $54 - http://www.oreillyauto.com/site/c/detail/FEL0/9854PT.oap?keyword=headgasket&pt=02289&ppt=C0026 Valve Cover Gaskets - $31 - http://www.oreillyauto.com/site/c/detail/FEL0/VS50395R.oap?keyword=valve+cover+gasket+set Thermostat/Radiator Flush - ~$35 - Subaru Link to comment Share on other sites More sharing options...
97400obw Posted January 19, 2011 Share Posted January 19, 2011 I'm no expert and most of my experience with these engines has been the reading type (other than my swap) and there are many different opinions on just about everything but I've seen one constant. USE GENUINE SUBARU HEAD GASKETS!!!!!!!! Or you will be doing this again........ Link to comment Share on other sites More sharing options...
97400obw Posted January 19, 2011 Share Posted January 19, 2011 Personally I'd buy a rebuild kit, hone the cyl's, put in a new set of rings and bearings. Freshen up the whole motor, very easy to do while you have it out. Link to comment Share on other sites More sharing options...
amigos1996 Posted January 19, 2011 Share Posted January 19, 2011 Well I decided to just go ahead with my engine build. This is my current list for when I go to do the camshafts. Any other suggestions? Also I put in headgaskets on because don't the heads have to come off? Camshaft Seals - $11 - http://www.oreillyauto.com/site/c/detail/FEL0/TCS45918.oap?keyword=cam+seals&pt=02344&ppt=C0026 - Subaru hi i hpe this helps http://library.alldatapro.com/alldata/LIB~C40593~R0~OD~N/0/41746574/56623499/56624059/110824586/34853741/100411974/34853743/34854590/34849578/106463962/106464013 Link to comment Share on other sites More sharing options...
ehsnils Posted January 19, 2011 Share Posted January 19, 2011 Are you going to change cams or? I suspect that it's a bit outside of your budget, but I did find a set here: http://www.xcceleration.com/engine-packages.html Link to comment Share on other sites More sharing options...
KuNomn Posted January 19, 2011 Share Posted January 19, 2011 Are you going to change cams or? I suspect that it's a bit outside of your budget, but I did find a set here: http://www.xcceleration.com/engine-packages.html Granted I'm sure these guys have done more research specifically on these engines but these prices seem a bit outrageous. My machine shop guy has tons of experience working with race engines (his and others) as well as plenty of subaru experience and could probably achieve 80% of these results for 25% of the price. Link to comment Share on other sites More sharing options...
Baddog Posted January 19, 2011 Author Share Posted January 19, 2011 Well I have been thinking about rebuilding the heads and I will be putting a delta 200 cam grind in. Nothing super huge. I should have mentioned I am going for just a little bit more power not balls to the wall. Amigo your link didn't work. Not sure why. Gives me an error. Link to comment Share on other sites More sharing options...
amigos1996 Posted January 19, 2011 Share Posted January 19, 2011 Amigo your link didn't work. Not sure why. Gives me an error. let me know if it works here is one more if this does not work i can send you an email http://library.alldatapro.com/alldata/LIB~C40593~R0~OD~ N/0/41746574/56623499/56624059/110824586/34853741/1 00411974/34853743/34854590/34850871/122633169 Link to comment Share on other sites More sharing options...
kaz98gt Posted January 20, 2011 Share Posted January 20, 2011 If you decide to tear down the whole engine, definitely do the piston rings and bearings at least. But for just the cams, that sounds like a good start...port and polish maybe? jk...take pictures!!! Link to comment Share on other sites More sharing options...
Baddog Posted January 20, 2011 Author Share Posted January 20, 2011 Since i plan on doing the head rebuild I will look at piston rings and bearings. Seems like they can be had (both) for around 150? I will be peicing parts together. Link to comment Share on other sites More sharing options...
Zues Marine Posted January 22, 2011 Share Posted January 22, 2011 let me know if it works here is one more if this does not work i can send you an email http://library.alldatapro.com/alldata/LIB~C40593~R0~OD~ N/0/41746574/56623499/56624059/110824586/34853741/1 00411974/34853743/34854590/34850871/122633169 stop posting alldata links, you need an account or an authorized computer to access the site, which 95% dont have Link to comment Share on other sites More sharing options...
