christurismohk Posted January 15, 2011 Share Posted January 15, 2011 I am thinking of getting 225/45/18 on my Rota Formula Mesh rims. Would the tires be a little stretched for the 8 inch width rims? I am going with 45 because I want the ride to be more comfy. Thanks all! Link to comment Share on other sites More sharing options...
wpmarky Posted January 15, 2011 Share Posted January 15, 2011 that's not stretched at all, it's pretty square. It kinda depends on the tire, some do run wider or skinnier than others, but in general 225 on 18x8 is just right. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted January 15, 2011 Share Posted January 15, 2011 225? Not at all a problem. 235/40 should square up nicely too Link to comment Share on other sites More sharing options...
iNVAR Posted January 15, 2011 Share Posted January 15, 2011 For an 05, closest size match (for the speedo) would be 225/40/18. 225/45/18 is larger, so your speedo will read lower. Link to comment Share on other sites More sharing options...
Drew888 Posted January 16, 2011 Share Posted January 16, 2011 The question really is if you can easily fit 235's and also be square....why aren't you buying the wider tire? [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
tantal Posted January 26, 2011 Share Posted January 26, 2011 No. 17x8 or 18x8 is good for 225. If you dont care about curbing your rim you could go with a narrower tire, but if you are interested in the best traction for 225, you should us a 9 inch rim - again only if you dont give a shit about curbing. Wider is better, but start with a wider _rim_ It is foolish to run 225/45/18 instead of 225/40/18 if you want a "comfy ride." You need to accept that comfort is important to you and do the sensible thing, which is to run 225/45/17 on a 17x8 rim. Actually, if you are concerned enough about the ride to do what you are suggesting you should save yourself the headache and buy a grand touring tire on the stock rims. It seems like you arent interested in performance. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted January 26, 2011 Share Posted January 26, 2011 x9" rims are not close to oem scrub radius (which is important for performance). I am running 245 on 18x8 and not only are they square, they flush up very nice on the car and have nearly the same amount of tread on either side of the centerline (DR31 Drag18x8+48 on 245/35/18 KDW2). I considered wider but for 265 and wider much more agressive camber is needed to take advantage for cornering (per several of our track guru on the forum) and thats just not great for a street car. link to see 245/35/18 on 18x8 D31 Drag http://legacygt.com/forums/showpost.php?p=3237716&postcount=65 Link to comment Share on other sites More sharing options...
tantal Posted January 27, 2011 Share Posted January 27, 2011 245/40 is not square on 18x8. Link to comment Share on other sites More sharing options...
Drew888 Posted January 28, 2011 Share Posted January 28, 2011 Hahahaha you knuckle heads, I see we are all "almost" saying the same thing but we all made some mistakes (probably due to posting too fast without reading). Ok, I didn't notice that the OP said 45 series to be "more comfy". I don't know how I missed that. We aren't noticing that LALGT mentions a 35 series tire he runs (almost missed that) and tantal actually missed it with his last response. I think we all need some sleep...lol. Especially the OP. Dude...go 225 or 235 on 40series on an 18" rim. The ride isn't bad at all. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
Drift Motion Posted January 28, 2011 Share Posted January 28, 2011 225/40/18 on 8 inch wheel is square anything wider is bulging out Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted January 28, 2011 Share Posted January 28, 2011 I noticed:rolleyes:. 225/45 may be a teeny bit tall. 225/40 is good but why not go 235/40 in that case which is similar to 225/45. I went 245/35 but it does rub a tiny bit at my height and I bet 245/40 would for sure. Link to comment Share on other sites More sharing options...
naimouasta Posted January 30, 2011 Share Posted January 30, 2011 235/40/18 on 18X8 /thread its just the perfect width/look and cushion/protection. http://img684.imageshack.us/img684/8759/22681165.jpg Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted January 30, 2011 Share Posted January 30, 2011 Gotta clear those corners /thread Link to comment Share on other sites More sharing options...
naimouasta Posted January 30, 2011 Share Posted January 30, 2011 nah i prefer amber corners. clear corners = plain, like a black and white photo, cool, but i prefer color. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted January 30, 2011 Share Posted January 30, 2011 (this thread is done so not going to stress on funny OT convo) Personally I love your silver on silver. IMO if you had the tint that has a slightly metallic look to it and clear corners it would be the cats meow - of course thats just me and its not mine. Link to comment Share on other sites More sharing options...
