2008_Legacy Posted January 10, 2011 Share Posted January 10, 2011 i got a 2008 subaru legacy special edition, 4 spd automatic. car has 64,000 miles on it now and starting to act up. all i wanna know is; does the engine have a timing chain in it??? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted January 10, 2011 I Donated Share Posted January 10, 2011 Nope, timing belt, but it's not due for a replacement until 105,000 mi. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 10, 2011 Share Posted January 10, 2011 Acting up like how? NO chain but maybe jumped a tooth on the belt. OH NOESSSSS Link to comment Share on other sites More sharing options...
2008_Legacy Posted January 11, 2011 Author Share Posted January 11, 2011 its making a noise, its like a clicking noise (like something loose/rubbing) when ever im driving (can hear it when its goin bout 70 mph) an when im accelerating/revving, at around 2500 rpm, noise is coming from the oil pan area. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 11, 2011 Share Posted January 11, 2011 could be an exhaust leak as odd as that sounds the escaping gases make that type of sound. Link to comment Share on other sites More sharing options...
burnout8488 Posted January 15, 2011 Share Posted January 15, 2011 ^^^^^^^^That. Could be really easy or really bad. Easy: exhaust leak, bad: mechanical damage. It's probably something simple....unless you never change your oil. Link to comment Share on other sites More sharing options...
akline5 Posted January 16, 2011 Share Posted January 16, 2011 sounds like a minor exhaust leak... ^^^haha Camry, someone called mine a camry yesterday! Link to comment Share on other sites More sharing options...
naimouasta Posted January 17, 2011 Share Posted January 17, 2011 check the radiator. first winter i had my car new, i got a bad rattle from the front at around 2k rpm. turned out the radiator does not sit tight. there is play in the pegs/stands at the bottom of the radiator that sit in the holes. i just shimmed it and it went away. http://img248.imageshack.us/img248/8778/radf.jpg Link to comment Share on other sites More sharing options...
Vinny78 Posted January 17, 2011 Share Posted January 17, 2011 sounds to me like a heatshield rattle mine does the same thing try getting under your car and looking at the heatshields on manifold, if they are loose or making noise take some self taping screws and screw them in halfway, i work at subaru and thats our number one complaint heat shield rattle Link to comment Share on other sites More sharing options...
2008_Legacy Posted February 9, 2011 Author Share Posted February 9, 2011 alrite guys, so i took my car to the dealer and all they could give me is internal mechanical problems, engine/trans runs good and car has no error codes. not sure wat it is, gonna take my engine apart in the next month, any ideas of wat i should try before goin thru wit it... Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 9, 2011 Share Posted February 9, 2011 alrite guys, so i took my car to the dealer and all they could give me is internal mechanical problems, engine/trans runs good and car has no error codes. not sure wat it is, gonna take my engine apart in the next month, any ideas of wat i should try before goin thru wit it... Internal Engine problems ? WTF ! You have a 08 if it is under warranty go back and tell them to figure it out. If you are going to tear down a your Ej253 you might as well replace all bearings, rings, gaskets and seals. Make sure you don't have a spun bearing or a bad tensioner Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted February 9, 2011 I Donated Share Posted February 9, 2011 He's at 64k. That's out of warranty. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 10, 2011 Share Posted February 10, 2011 bummer. Link to comment Share on other sites More sharing options...
