ibr_adam09 Posted January 5, 2011 Share Posted January 5, 2011 I need the part number (if there is one) for the O ring or crush washer that goes around the transmission drain plug because I'm leaking quite a lot of transmission oil. Based from the pictures it looks like it's coming from the plug because I don't see a trail of oil anywhere else. It might possibly be coming from the left cv axle because I do see an outline of oil around the green cup, but is there a seal for that as well? (And Yes I know my CV boot is torn and there's grease everywhere, but thats another issue and I have an order for a new one on the way right now.) I knew the leak has been happening sometime now, but after I did my tranny flush just a few days ago, its leaks a bit more rapidly In the first two pictures you can clearly see a drop of oil in mid air falling to the ground In the last picture you can see how much oil is on the ground. That's in a span of 3 hours Edit: was just a seal not all the way in the trans :/ Link to comment Share on other sites More sharing options...
amp0412 Posted January 5, 2011 Share Posted January 5, 2011 It could be from either. Yes there is a seal where the axle meets the transmission. Theres also a small spring in there that if the the axle was ever removed could have been lost in the process and would cause a leak, which is what happened to mine. I would clean the whole bottom of your trans in that area and go for a quick drive. If it's the axle you should be able to tell after that. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted January 5, 2011 Author Share Posted January 5, 2011 I would clean the whole bottom of your trans in that area That's what I did when I did my flush. That's why I took pics too see if you guys see a trail from anywhere else. As far as I can tell it's coming from the drain plug and I do see oil on the brim of the cv axle but no trail leading to the bottom of the transmission. Whats bothering me is how rapidly it's dripping from the plug. I mean I tightend it a breaker bar ! Thanks for the info about the spring. Ill be sure to order one at the dealer and install it when my new axle comes in. Would you know what the spring is called ? Link to comment Share on other sites More sharing options...
-The Boss- Posted January 5, 2011 Share Posted January 5, 2011 You sure thats trans fluid? Is it red? whats it smell like? http://i344.photobucket.com/albums/p330/ibr_adam09/SAM_0454.jpg In this pic your CV boot is ripped and you need to replace the axle. Its a fun job mine looked the same. Link to comment Share on other sites More sharing options...
dudeondacouch Posted January 5, 2011 Share Posted January 5, 2011 there is a seal where the axle meets the transmission. Theres also a small spring in there that if the the axle was ever removed could have been lost in the process and would cause a leak i bet it's this. those seals rip really easily. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted January 5, 2011 Author Share Posted January 5, 2011 You sure thats trans fluid? Is it red? whats it smell like? In this pic your CV boot is ripped and you need to replace the axle. Its a fun job mine looked the same. Its a manual trans, not automatic. and this stuff SMELLS and Like in my original post, I have a new axle on the way. Link to comment Share on other sites More sharing options...
amp0412 Posted January 6, 2011 Share Posted January 6, 2011 Its a manual trans, not automatic. and this stuff SMELLS and Like in my original post, I have a new axle on the way. Might want to grab the axle seal from the dealer as well. So that if it is leaking because of a bad seal you can replace it all at once and don't need to pull the axle twice. Good luck. Link to comment Share on other sites More sharing options...
Sideways the Seven Posted December 21, 2012 Share Posted December 21, 2012 I have the same problem (drain plug not axle seal). Does anyone have that part number. Sent from my GT-P3113 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
shadowsports Posted December 21, 2012 Share Posted December 21, 2012 This should be the one. 803926090 Link to comment Share on other sites More sharing options...
Sideways the Seven Posted December 21, 2012 Share Posted December 21, 2012 Thanks! Sent from my GT-P3113 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Max Capacity Posted December 21, 2012 Share Posted December 21, 2012 Heres what I have written down for the plug and gasket #s for the 5mt in the wagon Plug 32103AA080 Gasket 803926070 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Sideways the Seven Posted December 21, 2012 Share Posted December 21, 2012 Do they both need to be replaced? Sent from my LG-P999 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
doobaruGT Posted December 21, 2012 Share Posted December 21, 2012 yes...crush washers are cheap and if you use an old one there's no guarantee it will seal properly Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
Max Capacity Posted December 21, 2012 Share Posted December 21, 2012 Just the crush washer, I needed a new drain plug one time because it was overtighten and the torx70 teeth were in rough shape. I had to use a pipe wrench to remove the old plug. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted December 21, 2012 Share Posted December 21, 2012 Did you get this resolved? I had a track friend ignore a minor leak and in an over rev situation drop most of his fluid without noticing it. Got off the track just in time not to need to replace the entire tranny. Turned out he re-used the crush washer 3 times! Link to comment Share on other sites More sharing options...
Sideways the Seven Posted December 22, 2012 Share Posted December 22, 2012 Haven't done it yet, but she's parked. Going to the dealer in the morning for a clutch. Anyone want to recommend a good 350ishWHP one? Sent from my LG-P999 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
doobaruGT Posted December 24, 2012 Share Posted December 24, 2012 I love my competition stage II but do some searches and you'll find some info. http://www.infamousperformance.net/servlet/the-721/Competition-Clutch-Performance-Clutch/Detail Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
bluesuby Posted December 25, 2012 Share Posted December 25, 2012 yes...crush washers are cheap and if you use an old one there's no guarantee it will seal properly The copper washer on my transmission does not appear to be a crush washer. I have drained and refilled the tranny 6 or more imes and no leakage. I'm still going to buy a replacement because eventually any washer is going to be a problem. Link to comment Share on other sites More sharing options...
instantfury Posted December 25, 2012 Share Posted December 25, 2012 I thought I had the same problem, looked like it was leaking from the plug itself. Replaced the washer, no good. Still leaking. Used some brake cleaner and figured out it was the cv joint seals. Fyi. Link to comment Share on other sites More sharing options...
doobaruGT Posted December 26, 2012 Share Posted December 26, 2012 Axle seal, I had a similar problem now that I think about it Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
