silverbullet05 Posted January 5, 2011 Share Posted January 5, 2011 So the other day i noticed that my car was getting a little hard to turn after about a 1/4 to 1/2 turn of the steering wheel. I figured it was just a lot of snowed and ice packed in the car so i cleaned it up, and it is still hard to turn. It is weird, the power steering goes in and out and at complete random times. There is no noise associated with this, and thats why im confused. The belt is tight and like i said, no noises. For whatever reason nobody can order a power steering pump here in southern colorado except the dealer, who wants $500. Any thoughts??? Link to comment Share on other sites More sharing options...
Draco-REX Posted January 11, 2011 Share Posted January 11, 2011 Sounds like your pump. SGP has one for 307. https://www.subarugenuineparts.com/oe_parts_cat.html Link to comment Share on other sites More sharing options...
ineedone Posted January 30, 2011 Share Posted January 30, 2011 Hold off on the pump for now, do a flush first. Link to comment Share on other sites More sharing options...
iNVAR Posted January 30, 2011 Share Posted January 30, 2011 Stupid question but I still gotta ask. Did you check the fluid level? Link to comment Share on other sites More sharing options...
ronburgandy21 Posted February 2, 2011 Share Posted February 2, 2011 Make sure you don't have any air in your system. Check the reservoir for bubbles. If it does turn out to be a bad pump, I just replaced mine. Ordered a reman. one from Checker for 159.22 plus 30.00 for core charge. Works like new Link to comment Share on other sites More sharing options...
mustangendsley Posted February 2, 2011 Share Posted February 2, 2011 I just did a flush and put new Gaits racing belts on and works fine now. You shoud do that first. even if the belts are tight check them to see if all the grooves are there and no cracking. Link to comment Share on other sites More sharing options...
