Lookatmyrust Posted December 22, 2010 Share Posted December 22, 2010 Iv been getting pretty sick of the stock way or things.. cant tune, cant do one thing with out it causing a code or cripple the whole car.. so i was looking around and saw, mega squirt. now could i replace the stock ecu with this.... or link another ecu that doe this... just run what is needed for an efi engine to run. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 22, 2010 I Donated Share Posted December 22, 2010 Ah the good ol' megasquirt! lol This is an expensive project and not likely one that someone can do on their own at home unless you have very good knowledge about ECU mapping and wiring. First question is, do you have an automatic or manual transmission. If you're driving an automatic, then you will have to do a piggyback system. If you're driving a manual you can run a full stand alone ecu. With that being said, either way you go you're going to have to do a bunch of wiring. After all is said and done, you're going to have to get it tuned on a dyno each and every time you make some kinda change to the car. Its not really a plug and play kind of thing. There is A LOT involved in running a new ECU. As well, if you screw up your ECU settings, you will blow up your engine. Its best left to the pros who will charge you a few grand to do the complete job. Anyways, you will benifit almost nothing from a tune and ecu if your car is stock (or close to it). -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Baddog Posted December 22, 2010 Share Posted December 22, 2010 Exhaust,Intake,Cams with a piggyback ECU will give it some more power. Link to comment Share on other sites More sharing options...
Lookatmyrust Posted December 22, 2010 Author Share Posted December 22, 2010 ahh ok... figured it would be more simple with out all the emissions bull shit... maybe i should figure out how to delete some emission stuff. both on the engine and in the ecu Link to comment Share on other sites More sharing options...
Zues Marine Posted December 22, 2010 Share Posted December 22, 2010 emanage, rallitek, megasquit Link to comment Share on other sites More sharing options...
