brum Posted December 22, 2010 Share Posted December 22, 2010 Well this is for the cheapskates that don't want to drop the $130 on the UR or classics from RallyArmor. The universal flaps run $15 and I bought 4 stickers to spice them up a bit. http://i122.photobucket.com/albums/o264/rustycoupe/2010-12-21_22-30-00_939.jpg Use this guide as a complement to the RallyArmor installation instructions I kinda threw this together tonight in a couple hours. Some of the measurements are weird. It would be smart to slot the holes like the actual ones are as my rears are a little tilted. http://www.rallyarmor.com/store/legacy_instructions/legacy_ur_mounting_instructions.pdf There's the install instructions for the precut and drilled RA flaps. I used similar mounting hardware from my local hardware store. I used: (8) 1/4x20x1" hex headed bolts (2) 1/4x20x1.5" hex headed bolts (10) Polygon edge clips (check the site) (2) inside dia. of 1/4; half inch long nylon spacers. (10) 1/4" washers Then I reused two pop-its from the inner fender liner but I would suggest some longer ones as I had a hard time getting them to stay. Here are the crappy templates I threw together with measurements. I'll redraw them if someone can't read my crappy handwriting or wants a prettier version. The Circles are for drilling holes. I also cut down the fronts as a lot of the material is worthless. http://i122.photobucket.com/albums/o264/rustycoupe/2010-12-22_00-54-20_710.jpg http://i122.photobucket.com/albums/o264/rustycoupe/2010-12-22_00-54-07_843.jpg Link to comment Share on other sites More sharing options...
brum Posted December 22, 2010 Author Share Posted December 22, 2010 Let me know if theres any clarification needed and I'll be glad to help out! Link to comment Share on other sites More sharing options...
SlickSpur Posted January 10, 2011 Share Posted January 10, 2011 Looks pretty nice to me, I'll have to give this a go once the weather warms up. Link to comment Share on other sites More sharing options...
Brock Samson Posted August 18, 2011 Share Posted August 18, 2011 Did you ever re-do this template? I've been looking for a good mudflap template. Link to comment Share on other sites More sharing options...
brum Posted August 19, 2011 Author Share Posted August 19, 2011 Nope ill probably mess with it this fall before winter. The rears could probably be fixed by just adding an 1/8 of an inch or so onto the 6 1/4 measurement Link to comment Share on other sites More sharing options...
T_Altland27 Posted February 7, 2014 Share Posted February 7, 2014 Way better then spending $130 on them cost me $15 for all four $11 in shipping and $20 for hardware took about an hour or so installing and they look just like the $130 ones Link to comment Share on other sites More sharing options...
DonnyJagaru Posted February 7, 2014 Share Posted February 7, 2014 I spent $20 for no-name brand at the local auto parts store. I used snap-in fasteners from there as well which worked with the factory holes. Don't mount them too low otherwise they'll get ripped off when you back over a curb or small rise. Link to comment Share on other sites More sharing options...
