Legacy Wagon Posted December 7, 2010 Share Posted December 7, 2010 My woman has a 2001 Pontiac Grand Prix. When we go over bumps the rear suspension is kind of clunky :/ I figure it's the suspension at least. I've heard possible sway bar or bushings, but that seems like a weird opinion to me cause I figured the bar's either good or not and the bushing wear out or they dont. Anyway, if anyone has any clues about what it could be let me know. It's mainly when you go over really slow it hits hard when the rear suspension hits a speed bump, but it'll do it pretty loud when you hit a bump at higher speed too. I doubt it's anything in the trunk, but tonight's the first time I've heard it and it gets dark before I even get home these days :/ Thanks guys Link to comment Share on other sites More sharing options...
Legacy Wagon Posted December 8, 2010 Author Share Posted December 8, 2010 No ideas? Link to comment Share on other sites More sharing options...
amorgan93 Posted December 8, 2010 Share Posted December 8, 2010 No ideas? hmm my 1994 saturn sl2 use to do this only at low speed when hitting a bump and it was sway bar bushings. but that was on the front and the car had rear sway bars. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted December 8, 2010 Share Posted December 8, 2010 Check sway bar links. My ex's father had a Grand Prix and the endlinks were shot and it was making one hell of a noise. The endlinks will wear out and go bad. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted December 10, 2010 Author Share Posted December 10, 2010 Thanks guys! I'll check them out this weekend. Link to comment Share on other sites More sharing options...
grmorrow04 Posted December 10, 2010 Share Posted December 10, 2010 Definitely sounds like an endlink issue. Moog units are much beefier than the stock ones, I think they are around $50 for a pair (but don't quote me on that). Also make sure that the strap that holds the bar/bushing in place isn't torn away from the subframe piece... I had that issue on a 2000 GTP I used to have. And FYI, the swaybars can go bad in those cars; mainly it's the front ones as they break near the endlinks (water gets inside and starts to corrode them; since they are hollow they don't take much to break). Link to comment Share on other sites More sharing options...
ehsnils Posted December 10, 2010 Share Posted December 10, 2010 Clunks can also be the shock absorbers when they get old. Gas filled shocks when the compressed gas has leaked. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted December 11, 2010 Share Posted December 11, 2010 +1 for the endlinks. They're cheap and easy to replace. So are sway bar bushings. Also check the condition of any other bushings you see under there. You can also bounce the car up and down and wobble it side to side to try and recreate the noise. If you have someone else try wobbling the car around while you're underneath it you might be able to pinpoint the noise. Just don't squish yourself. Link to comment Share on other sites More sharing options...
meier motor sports Posted December 11, 2010 Share Posted December 11, 2010 links and/or bushings are a likely cause. but it could be almost anything Link to comment Share on other sites More sharing options...
