laxdudeee Posted November 24, 2010 Share Posted November 24, 2010 Yesterday I got in my car and turned the key and nothing happened. No click, no grind, nothing. After being persistent with it it finally started. I drove for an hour then had no problems re-starting the car on several occasions that night. The next morning same thing, nothing. It took a little longer to get it to start this time though. I can only image the next time I go to start my car its going to be impossible... Does this sound like a problem with the starter or the ignition? TIA Eric Link to comment Share on other sites More sharing options...
Strizzy Posted November 24, 2010 Share Posted November 24, 2010 Sounds like the battery. How old is it? My bad luck build Link to comment Share on other sites More sharing options...
m sprank Posted November 24, 2010 Share Posted November 24, 2010 How cold it it? How old is the battery? How dirty are the connections at the battery? I think Strizzy is pointing in the right direction. Link to comment Share on other sites More sharing options...
laxdudeee Posted November 24, 2010 Author Share Posted November 24, 2010 The only reason why I didn't think battery right off the bat was that the car has not labored to start a single time. The temperature has been in the mid 40's all week. I just bought the car a month ago so I am unsure of the age of the battery. Definitely going to re-do the battery terminals and see if that clears it up. Do these cars ever have issues with the immobilizer in the key? I've heard of that being an issue on other cars. One thing I did just do was attempt the "20 click" method to disable the seatbelt chime, I can't imagine that having any affect but thought I would just throw it out there. Thanks again! Link to comment Share on other sites More sharing options...
m sprank Posted November 24, 2010 Share Posted November 24, 2010 Never had issues with the key or car not starting. I would start with the simple stuff. Check the battery and terminals. There is a main ground that goes next to the starter. It is at the tranny (on top) just under the intercooler. Clean that bad boy up too. It is a bolt, easy to remove and clean. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 24, 2010 Share Posted November 24, 2010 Yep, clean the connections first. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
