crossxc13 Posted November 11, 2010 Share Posted November 11, 2010 Hey all, I had the 2.5L taken out and replaced with 2.2L, but the check engine light still comes, checked it out and it is caused by the EGR Value, which is in installed. Is there a way to take that code off the computer or what? Thanks. Link to comment Share on other sites More sharing options...
kaz98gt Posted November 11, 2010 Share Posted November 11, 2010 Is it a flashing CEL? Mine is swapped in with a 2.2, and the guys before unplugged a certain green connector under the dash to stop it from coming on. I'm not sure what the code is (never had a chance to plug in the obd reader to pull the code when the wire was connected), but maybe you're having the same kind of thing. Link to comment Share on other sites More sharing options...
johnegg Posted November 12, 2010 Share Posted November 12, 2010 Hey all, I had the 2.5L taken out and replaced with 2.2L, but the check engine light still comes, checked it out and it is caused by the EGR Value, which is in installed. Is there a way to take that code off the computer or what? Thanks. what year, model and trans did the engine come out of?? Link to comment Share on other sites More sharing options...
crossxc13 Posted November 12, 2010 Author Share Posted November 12, 2010 kaz98gt: I checked and that wire was already unplugged, I tried plugging it back in and it then started to blink. So I unplugged it again and it is still on when I drive. I do not remember the year or model. Shoot Link to comment Share on other sites More sharing options...
kaz98gt Posted November 12, 2010 Share Posted November 12, 2010 Yeah mine is the same way with the blinking cel. If you are ABSOLUTELY SURE there's nothing wrong with the egr system, have a shop clear the code for you. I have a system called proscan on my laptop with a connector cable for around $150, and it lets you pull codes and clear them and alot more. That's what I've done for any wrong codes. Link to comment Share on other sites More sharing options...
crossxc13 Posted November 12, 2010 Author Share Posted November 12, 2010 Yeah mine is the same way with the blinking cel. If you are ABSOLUTELY SURE there's nothing wrong with the egr system, have a shop clear the code for you. I have a system called proscan on my laptop with a connector cable for around $150, and it lets you pull codes and clear them and alot more. That's what I've done for any wrong codes. Which Proscan did you buy? Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted November 12, 2010 Share Posted November 12, 2010 Hey all, I had the 2.5L taken out and replaced with 2.2L, but the check engine light still comes, checked it out and it is caused by the EGR Value, which is in installed. Is there a way to take that code off the computer or what? Thanks. Did you check the EGR valve itself? If even one of those tiny rubber hoses were knocked off, it'll throw a code. There are 2 ways to remove the code: Resetting your ecu will do this. A scan tool with a CEL removing function will do this. Link to comment Share on other sites More sharing options...
crossxc13 Posted November 12, 2010 Author Share Posted November 12, 2010 I did check the value it is good working. What scan tool would you recommend? Thank you so much btw Link to comment Share on other sites More sharing options...
stiwanabe Posted November 12, 2010 Share Posted November 12, 2010 what difference does clearing the code make? if the fault is still present its gonna come back on. Link to comment Share on other sites More sharing options...
kaz98gt Posted November 13, 2010 Share Posted November 13, 2010 ^^ If there isn't a fault anywhere in the system then he can clear it. You have to be absolutely sure of it though. When I had an exhaust leak I was getting a cel for an exhaust leak, and after I welded up a new piece of pipe I still had the code. So, I just cleared it. cross, check this out: http://www.myscantool.com/ Link to comment Share on other sites More sharing options...
stiwanabe Posted November 14, 2010 Share Posted November 14, 2010 well yeah. you clear the code after you fix the problem that caused the code. Just clearing the code without fixing the problem does no good. Link to comment Share on other sites More sharing options...
johnegg Posted November 15, 2010 Share Posted November 15, 2010 the parts stores will usually check the codes for you for free. but you need to ask what the code number is. you probably have a small vac line left unconnected. follow the picture on the hood and track each hose as listed. make sure the ''stuff'' on the passenger strut tower is connected. check the filter in the hose going to the ''stuff'' on the strut tower. do you have an exhaust leak? did you reconnect the charcoal canister in the front of the engine bay.? Link to comment Share on other sites More sharing options...
JBethell80 Posted November 25, 2010 Share Posted November 25, 2010 Not to jack the thread, but being a subie newb, I have to ask, why pull the 2.5 in favor of the 2.2?? I always thought the 2.5 was more desirable?? Link to comment Share on other sites More sharing options...
kaz98gt Posted November 25, 2010 Share Posted November 25, 2010 In a nutshell, the 2.2 is bulletproof. It will run and run as long as you change the fluids regularly. The 2.5's major downfall was the bad headgaskets on the DOHC for the 2nd gen and the SOHC for the 3rd gen. They did a poor design for them, and they'd burn out anywhere between 100 and 150k miles (granted, some have lasted alot longer, but that's a small percentage). The people who don't know anything about an overheating engine probably ran the car continuously and warped the heads beyond repair. So, they swap in a 2.2 and forget about it. You lose around 30hp and tq, but gain alot for reliability. Link to comment Share on other sites More sharing options...
JBethell80 Posted November 25, 2010 Share Posted November 25, 2010 ^ Thanks Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted November 25, 2010 Share Posted November 25, 2010 I don't know if the EJ22 exactly 'loses' 30hp/tq when used in an Outback since the ECU changes it a little bit when they are combined (ECU makes the EJ22E rev a little higher & gives it more fuel among other things.) I would say about 15-20hp at best. Link to comment Share on other sites More sharing options...
crossxc13 Posted November 28, 2010 Author Share Posted November 28, 2010 Yeah the 2.2L is awesome. Link to comment Share on other sites More sharing options...
