Duker Posted November 2, 2010 Share Posted November 2, 2010 I was all excited to finally get my Fumoto EZ oil drain valve installed on my oil change today, only to have it not fit. Could someone help me out here? I have the F-105 which is the correct Subaru part number for this valve but when I went to install it, it was too small! Threads wouldn't even begin to engage, I can wiggle it around in the opening. Has anyone else had this problem in the their 2005 LGT? I didn't see this coming, I figured basically all Subaru's would have the same size oil drain plug. help Link to comment Share on other sites More sharing options...
TRS Posted November 2, 2010 Share Posted November 2, 2010 Possible that you were sent the wrong/mislabeled valve. I don't recall if there was any actual marking on the valve itself to identify the part number. Link to comment Share on other sites More sharing options...
johnAWD Posted November 2, 2010 Share Posted November 2, 2010 I can't install mine (05 LGT) due to a cross member being in the way - can't screw it in. I need to get the car on jackstands and wrench a bit to get it to engage. Threads are correct. Link to comment Share on other sites More sharing options...
elib Posted November 2, 2010 Share Posted November 2, 2010 Just installed mine minutes ago. It says 105 on the side. Fit perfect, miles away from the x-member. It is the lowest thing on the engine though which I dont like. Link to comment Share on other sites More sharing options...
Duker Posted November 2, 2010 Author Share Posted November 2, 2010 Possible that you were sent the wrong/mislabeled valve. I don't recall if there was any actual marking on the valve itself to identify the part number. Thats what I thought to, but even the valve itself is marked as "F 105", hmmmmmmm. Unless the part was actually stamped with the wrong label? Although that seems unlikely. I guess I'll just have to go to the dealer and compare it with another valve of the same part # Link to comment Share on other sites More sharing options...
elib Posted November 2, 2010 Share Posted November 2, 2010 Are you the first owner? Is it possible that. Someone stripped the drain plug at some point and had to rethread with a larger size plug? Ever have an oil change that took a long time:) Link to comment Share on other sites More sharing options...
Duker Posted November 2, 2010 Author Share Posted November 2, 2010 Are you the first owner? Is it possible that. Someone stripped the drain plug at some point and had to rethread with a larger size plug? Ever have an oil change that took a long time:) Hmmm, interesting. No I am the second owner. What size is the standard drain plug? The one is mine uses a 14mm socket but the actual thread is around at least 20mm Link to comment Share on other sites More sharing options...
CTATV Posted November 2, 2010 Share Posted November 2, 2010 Are you the first owner? Is it possible that. Someone stripped the drain plug at some point and had to rethread with a larger size plug? Ever have an oil change that took a long time:) +1 that would be my first thought Link to comment Share on other sites More sharing options...
elib Posted November 2, 2010 Share Posted November 2, 2010 My 08 takes a 17mm socket Link to comment Share on other sites More sharing options...
Duker Posted November 2, 2010 Author Share Posted November 2, 2010 My 08 takes a 17mm socket Interesting....... damn. Looks like I'm gonna have to look through all the sizes that fumoto offers and match my non-standard plug hole if I want to go with one. Thanks everyone for the help, guess I'll be sticking with the regular drain plug for a while longer. Link to comment Share on other sites More sharing options...
bighaus90 Posted November 4, 2010 Share Posted November 4, 2010 +1 for it being rethreaded I had to do that to my last car. Link to comment Share on other sites More sharing options...
AZP Installs Posted November 8, 2010 Share Posted November 8, 2010 I would caution on Fumoto Valves. We've seen a few of them inadvertantly open up on people, especially at the race track. -mike Link to comment Share on other sites More sharing options...
bighaus90 Posted November 8, 2010 Share Posted November 8, 2010 They make a locking clip for them to avoid them opening. Link to comment Share on other sites More sharing options...
AZP Installs Posted November 8, 2010 Share Posted November 8, 2010 Cool, that must be new, haven't used/seen em in a few years. -mike Link to comment Share on other sites More sharing options...
