dan04103 Posted March 27, 2013 Share Posted March 27, 2013 Bumping this dead thread. Can anyone explain how to actually adjust the rear camber bolt once it is installed? Is there a special type of tool used to turn the whiteline metal sleeve? I want to at least get them close before an alignment. I use a an old screwdriver I had around that fit and cut the tip off. You could also you a nail setter or even a set of tongue & groove plyers. Good luck. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 27, 2013 Moderators Share Posted March 27, 2013 Those who have the bushings in their car, what are your post-install impressions? hicksta just installed them--although he also put on brand new tires...probably hard to tell the difference there. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
dan04103 Posted March 27, 2013 Share Posted March 27, 2013 Those who have the bushings in their car, what are your post-install impressions? I really like them. Not too difficult to adjust as I do my own alignments. Able to get my rear camber dialed to within 0.1deg side to side. Link to comment Share on other sites More sharing options...
SCHM1AN Posted March 27, 2013 Share Posted March 27, 2013 hicksta just installed them--although he also put on brand new tires...probably hard to tell the difference there. I just sent hicksta a PM, currently awaiting his review I really like them. Not too difficult to adjust as I do my own alignments. Able to get my rear camber dialed to within 0.1deg side to side. Are you able to tell if the rear feels any more planted than before? I'm looking to get these to help out in autocross Also, 2000th post Link to comment Share on other sites More sharing options...
dan04103 Posted March 27, 2013 Share Posted March 27, 2013 OP just as a sanity check make sure to inspect your rear trailing bushing. I had a similar problem to yours (my rear ride heights were off though so check this symptom in addition). Mine were separating from the metal sleeve and were causing alignment issues and safety issues... yikes. Its the large bushing mounting the rear arm to the frame. Link to comment Share on other sites More sharing options...
dan04103 Posted March 27, 2013 Share Posted March 27, 2013 Are you able to tell if the rear feels any more planted than before? I'm looking to get these to help out in autocross Also, 2000th post Yes. Check this article out for awd alignment. http://www.turbomagazine.com/tech/0711_turp_awd_alignment_tips/viewall.html Cheers Link to comment Share on other sites More sharing options...
robinlsb Posted March 27, 2013 Share Posted March 27, 2013 Looking to see if anyone has the whiteline KCA399 camber kit, looked all over the internet of installed pictures to see exactly where these guys go and can't find anything. Anyone have any installed pictures on location? Debating if i should install my coilovers now, or wait on them that will be here in 3 more days. I might drive ummmm 40miles max within the next 3 days so that is why am asking. I didn't like them. They worked, but without being able to adjust the rear toe (with that stupid concentric bolt) at the same time, they were not helpful. Change the camber, and you change the rear toe. The stock toe bolts are worse than useless, if you can't dial in the rear toe in. Change the camber and you put the toe out of synch, Change the toe, and the camber is wrong. The Whiteline KT124 kit is the only part set that allowed me to dial in the rear suspension. And I could ignore the stupid stock toe adjusters. Pricey, and they refused to sell me just the adjustable toe arm. However, the combination allowed me to set the rear suspension, on each side to a perfect specification. It made a World of difference in high speed corners:) "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
.Catalyst. Posted March 27, 2013 Share Posted March 27, 2013 For mild drops they work great to adjust rear camber. My alignment tech had no problem getting me the desired camber (and zero toe) with them installed. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
JohnnyT Posted April 12, 2013 Share Posted April 12, 2013 I just got these. I hope my mechanic and alignemnt guy doesn't run into any problems. I my case the LR tire is wearing on the outside. Link to comment Share on other sites More sharing options...
