2005gt35r Posted October 20, 2010 Share Posted October 20, 2010 now that the spark plug problem is all worked out in my dads car, now i can get to understanding the car hopefully, with you guys's help. the car is a 2005 Legacy GT. what i believe is a Garrett 35r, racing clutch, FMI, BOV, catless exhaust, cobb tuning and some other things that either i just cant remember or just don't know about. its currently running about 18PSI we were told the car made 400HP. i have no clue if this is a realistic number or not. ill try and get some videos of it driving soon. how do i tell what computer/tuning work it has done? also will this pass emissions? the PO said it would, theirs no check engine light, and when i plugged in the OBD in school it said "catalyst: ok". thanks. Link to comment Share on other sites More sharing options...
Strizzy Posted October 20, 2010 Share Posted October 20, 2010 Depending on how your emissions is tested, it may or may not pass. If your state just plugs into your OBD2 port to check for any faults, you will be alright. If your state puts your car on a dyno and tests what's coming out of your tailpipes, you have a good chance of not passing. Same goes if they also do a visual inspection and don't see any catalytic converter. My bad luck build Link to comment Share on other sites More sharing options...
2005gt35r Posted October 20, 2010 Author Share Posted October 20, 2010 well the place were going to isn't to strict. they don't do the dyno, and the car is wicked low to the ground, so to do a visual they would probably have to lift it, and they wont do that. i guess all i can do it wait and see Link to comment Share on other sites More sharing options...
Max Capacity Posted October 20, 2010 Share Posted October 20, 2010 You should contact Mike at http://www.tuningalliance.com/ He tunes my car and can answer most if not all your questions. He's in W.Springfield. Where are you in MA ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
2005gt35r Posted October 21, 2010 Author Share Posted October 21, 2010 right near Worcester. ill check out that website thanks. when should my dad start doing that thing were you let the car idle for a minute after running because its so cold? like what temp should he start doing that. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 21, 2010 Share Posted October 21, 2010 Worcester, then check out http://enhancedstreetperformance.com/ I had them install my catless up/down pipes last month. Mike recommended them. It's a learned process, when it needs to cool. Like I've said, I can coast a lot when I get to the ends of my drive. Yesterday I stopped by Big Y right off Rt84 after the drive from work, 25 minutes at 70mph. I coasted the last 1/2 mile down to the off ramp. the light was green at the exit ramp. Went about 400ft pulled into Big Y, parked and shut it off, I didn't let it idle. Even in Aug, I would do the same thing. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
