elib Posted October 17, 2010 Share Posted October 17, 2010 I'm trying to get some data logs together for Infamous1 and every time I start logging my AP craps out after a few seconds it seems. It says that it's lost the connection to the AP and then it resets and starts showing data again, but stops the log. I can't get a full 2k-7k pull even. Anyone seen this before? I've tried two USB cables and that didn't seem to help. It runs fine the rest of the time and I was able to flash the last map he sent me no problem. Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted October 18, 2010 Share Posted October 18, 2010 If I pick too many items to log a time (or accept Cobb's default values) mine does the same thing. I started out and just picked out a handful of items, kept adding additional parameters until I had the bare minimum required by my tuner. Think there were one or two that always caused it to freeze up, but I can't recall off the top of my head.....and my unit is in for repair as the screen recently went out on it. Link to comment Share on other sites More sharing options...
goneskiian Posted October 18, 2010 Share Posted October 18, 2010 Is it shaking loose at the OBD port? Link to comment Share on other sites More sharing options...
elib Posted October 18, 2010 Author Share Posted October 18, 2010 I haven't had a chance to check but I think this is it. I remember noticing that after the update (I think) all of my log options were checked where as they weren't before. I'll check tomorrow when I'm back around my car and update. If I pick too many items to log a time (or accept Cobb's default values) mine does the same thing. I started out and just picked out a handful of items, kept adding additional parameters until I had the bare minimum required by my tuner. Think there were one or two that always caused it to freeze up, but I can't recall off the top of my head.....and my unit is in for repair as the screen recently went out on it. Link to comment Share on other sites More sharing options...
elib Posted October 18, 2010 Author Share Posted October 18, 2010 Is it shaking loose at the OBD port? I tried that one already It will monitor data for hours, just not log. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted October 18, 2010 Share Posted October 18, 2010 make sure you have the latest firmware update On the search for a new DD... Link to comment Share on other sites More sharing options...
elib Posted October 19, 2010 Author Share Posted October 19, 2010 If I pick too many items to log a time (or accept Cobb's default values) mine does the same thing. I started out and just picked out a handful of items, kept adding additional parameters until I had the bare minimum required by my tuner. Think there were one or two that always caused it to freeze up, but I can't recall off the top of my head.....and my unit is in for repair as the screen recently went out on it. That did it. Too much data being logged kills the AP Link to comment Share on other sites More sharing options...
