f1anatic Posted October 8, 2010 Share Posted October 8, 2010 It may sound completely random but that is exactly my question: Question 1:If you upgraded to a Walbro fuel pump - did that cause interference with the quality of the display on your CarPC; OEM or aftermarket unit ? Question 2: Are you running a Walbro 255 fuel pump and have no display issues ? Question 3:Were you using a Xenarc TSV 700 and it crapped out on you ? In the span of 2 weeks, my laptop running the CarPC crapped out. Then I was scheduled to go Stage 3 so I took the car in to a very very reputable outfit (and I do not mean a tuner shop) and when I got it back, my monitor was not displaying well - it looked like heavy interference and a "rain" effect on the screen. Unusable. I thought they may have spliced a wire by accident when they put back my rear seat (my CarPC was in the trunk). Took seat off. Nope. Nice and tidy. I thought it was the power source. Had a spare one. Replaced. Nope. Meanwhile I had purchased a Foxconn NetTop PC to replace my 8 year old laptop whose USB ports suddenly stopped working. Well 250 bucks into the navi ordeal...I know have to order a screen. But I thought I just check with you and see if it is the...pump. When I use my walkie talkies in the car (4 Watt ICOM professional radios), they used to get a lot of interference from the screen. So I am thinking maybe the reverse is possible. Some electronic gizmo to interfere with the monitor. Please advise. thanks. Link to comment Share on other sites More sharing options...
f1anatic Posted October 8, 2010 Author Share Posted October 8, 2010 bump so i can hopefully have an answer before i order a screen Link to comment Share on other sites More sharing options...
Th3Franz Posted October 8, 2010 Share Posted October 8, 2010 You could try putting some ceramic capacitors in parallel with the power source to the monitor to see if that helps -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
m sprank Posted October 8, 2010 Share Posted October 8, 2010 No issues with my dual screens and walbro set up. OEM and Kenwood screens. Link to comment Share on other sites More sharing options...
