baj Posted September 16, 2010 Share Posted September 16, 2010 I have a new transmission drain plug washer/gasket for my 2006/2007 5MT. The part number is 803926090. There is metal in it, silver colored, so I think it might be aluminum but there is a black non-metalic layer on both sides. The dealership I got it from said that it was a new fiber washer that had recently superseded the old part. The 2007 service manual says to torque the drain plug to 32.5 ft-lbs if using an aluminum gasket, and to 51.6 ft-lbs with a copper gasket. Does anybody know what the torque should be with this newfangled gasket? Link to comment Share on other sites More sharing options...
cypher0117 Posted September 16, 2010 Share Posted September 16, 2010 As hard as you can?My drain plug feels tighter than my lugnuts (85ft-lbs). Anyways I was using the same braker bar I use on my lugs and couldn't brake my trans plug loose.I wouldn't recommend this but I also have a new drain plug and non-metal washer and would be interested in knowing the torque for whenever I do get the old one out. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 17, 2010 Share Posted September 17, 2010 Only tight enough so it doesn't leak. I won't put it in there to tight. You know how hard they can be to remove. You can alway's make it a bit tighter if it leaks a little. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
