slm90legacy Posted September 6, 2010 Share Posted September 6, 2010 will any parts from a 1995 Legacy L work on my 1990 Legacy L? I need an air compressor, and a seatbelt motor, and a couple other various items. I found a posting on craigslist where a guy is parting out a 95 legacy l... Thanks in advance Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 12, 2010 I Donated Share Posted September 12, 2010 I think you're out of luck on this one. I know for a fact that the a/c compressors are different.... similar but different (confirmed this with part numbers on autozone.com). As far as anything else, I wouldn't think it would be compatible. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Platinum_Racing Posted September 14, 2010 Share Posted September 14, 2010 In 1995 when Subaru put dual frontal air bags in the Legacy the automatic seat belts were removed. Thus, the 1995 Legacy shouldn't even have automatic seat belts. When you say "Air pump" there are several possibilities. If you're talking about the pump for the optional air ride suspension on the 1990 Legacy, you're out of luck. The second gen Legacy didn't have air ride suspension, thus it didn't have an air pump. If you're talking about the AC compressor you might be in luck. There were several different styles of compressors for the EJ22. They should all be interchangeable though. If the price is right and you can be 100% sure that this used AC compressor actually works, it could be worth a try. The only problem is the rest of the system is made to use R12 refrigerant and the AC compressor from 1995 is made to use R134a refrigerant. I'm not sure if you'll have to do any retrofitting to make the system work properly. As far as the compressor fitting in the car, and bolting up you should be all good. Link to comment Share on other sites More sharing options...
