SpecBGuy Posted September 1, 2010 Share Posted September 1, 2010 i was about to install my KB front and rear shift brushing following the instructions on this forum but then the diy pics are for 5spd. so i got confused cuz it looks different. is this the front shift brushing part i just want to make sure before i swap it out. is there a 6spd instructions? http://img641.imageshack.us/img641/7408/0829001315.th.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted September 1, 2010 Share Posted September 1, 2010 Yes that should be the front brace. Looks the same as the one I just replaced on my son 01 Integra. They are all pretty much the same. Pull that bolt out, pry out the old bushing, put a little liquid dish soap on the new bushing and push it in . 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Strizzy Posted September 1, 2010 Share Posted September 1, 2010 Search for front bushing install for a STi, since it is basically the same as our 6MT. I remember when I attempted to to the install myself and got to the point of trying to get the shifter linkage bolt out, but it wouldn't come out unless I dropped the trans a few inches. I said screw it and had it installed when my new clutch went in, since it would already be apart. Here's install instructions from Perrin: http://www.perrinperformance.com/shared/PERRIN/documents/instructions/subaru/pspinr010.pdf My bad luck build Link to comment Share on other sites More sharing options...
wpmarky Posted September 1, 2010 Share Posted September 1, 2010 Dropping the tranny is easy. I tried to do it at first without dropping the tranny, and couldn't get the bolt out. Then when I spent 15 mins to lower the tranny a bit with my jack, the rest of the install was a piece of cake. Should take no more than an hour. Link to comment Share on other sites More sharing options...
SpecBGuy Posted September 1, 2010 Author Share Posted September 1, 2010 omg i need to drop the tranny too. why cant it be easy like 5spd shiet Link to comment Share on other sites More sharing options...
wpmarky Posted September 1, 2010 Share Posted September 1, 2010 it's not even really dropping the tranny. Unbolting the support brace and lowering it an inch takes like 5-10 mins. Link to comment Share on other sites More sharing options...
SpecBGuy Posted September 1, 2010 Author Share Posted September 1, 2010 it's not even really dropping the tranny. Unbolting the support brace and lowering it an inch takes like 5-10 mins. i dont even know where the lowering brace is:redface: can i see it when i go under the car? do i really need a jack to hold it or will it hold on, on its own? Link to comment Share on other sites More sharing options...
