camroncamera Posted June 14, 2012 Share Posted June 14, 2012 That's what I meant. Where can you get those Scotchlok taps? And yes, that's the only non-plug and play part of the install. But it's all good. Not difficult at all to solder a connection to. They are available at most any auto part stores, but they are often not recommended due to the way they tear into the wires that they tap. A T-Tap would be marginally better, but it sounds like Posi-Taps are the way to go: http://amzn.com/B00389R8KU Link to comment Share on other sites More sharing options...
David E Posted October 8, 2018 Author Share Posted October 8, 2018 Anyone have a trick to get the bottom grill clips out without breaking them? Ok, FSM says just pull to get bottom ones out. Pretty scary, but it did work. Link to comment Share on other sites More sharing options...
Setnev Posted October 13, 2018 Share Posted October 13, 2018 Anyone have a trick to get the bottom grill clips out without breaking them? Ok, FSM says just pull to get bottom ones out. Pretty scary, but it did work. I have a very long flathead screwdriver that i go in from the bottom of the bumper and I push the tabs in while gently pulling outwards on the grille. Link to comment Share on other sites More sharing options...
