Phila Posted August 28, 2010 Share Posted August 28, 2010 Its a shame, but I think we all need to just accept the fact that the interior quality of our cars is terrible. The only way to take care of these problems is to take the interior apart and somehow pad each piece of cheap plastic so that they no longer rub against each other. I may have to look in to that small heat shield in the center of the dash that 05LGT mentioned... Link to comment Share on other sites More sharing options...
mad99 Posted August 30, 2010 Author Share Posted August 30, 2010 Yeah, I realize the interior isn't going to be perfect, I'm just trying to get whatever I can fixed before the warranty is up. Link to comment Share on other sites More sharing options...
mad99 Posted September 2, 2010 Author Share Posted September 2, 2010 To follow up, I could not find the content of these TSB's. Rattle/Squeak Noise from Instrument Panel Service Bulletin #12-96-06 Noise from Combination Meter (Revised) Service Bulletin #08-34-05R I gave the names and numbers to a Subaru service writer, and he later told me the first one applies to 05 and 06 Legacy's, and that the 07 was redesigned to fix the issue and the TSB does not apply. (So why do 07's still rattle?) He said the second one applies to the Forester. Tomorrow the car goes in again, so they can replace the "dash pad". We'll see. Link to comment Share on other sites More sharing options...
dschultz Posted September 3, 2010 Share Posted September 3, 2010 I guess you missed this post? Link to comment Share on other sites More sharing options...
mad99 Posted September 3, 2010 Author Share Posted September 3, 2010 Hmm, yeah, somehow I did miss that post. It seems like the "View First Unread" feature does not always work properly. Thanks. That TSB does seem like that could be the problem, or part of it, but the dealer said something was redesigned for 2007 so this TSB doesn't apply. Update: took car in for installation of a new "dash pad" but after they worked on my car half the day they noticed the new part was broken, and they have to order another one. Link to comment Share on other sites More sharing options...
Phila Posted September 11, 2010 Share Posted September 11, 2010 I have a new rattle that has appeared this week, it sounds like its coming from the seatbelt where it is attached to the car at the height adjustment piece. Whenever I go over a small hump (rather than a sharp bump) it rattles the most. I think its the adjustable piece itself that is making all the noise. This is getting out of control. Its a 3-year-old car. These problems should not exist. edit: Its not coming from the seatbelt adjustment. Crap Link to comment Share on other sites More sharing options...
loopless Posted September 13, 2010 Share Posted September 13, 2010 Try some lubrication on the door latch mechanism. Napa sell a CRC aerosol lithium grease spray that works wonders. Any contact in the latch area can "travel" up the B pillar. Link to comment Share on other sites More sharing options...
Phila Posted September 13, 2010 Share Posted September 13, 2010 Thanks for the suggestion! It seems as though its definitely coming from inside the B-pillar somewhere. It also has a distinct plastic sound. If you were to tap against the adjustment piece of the seatbelt on the B-pillar that moves up and down, it sounds just like that, thats why I thought that was the culprit.. but I was proven wrong when I put some "padding" in there. Link to comment Share on other sites More sharing options...
maniaxzero Posted September 13, 2010 Share Posted September 13, 2010 it drove me absolutely nuts.... so I took a folded 8x11 piece of paper and wedged it between dash and windshield by the A pillar. Voila! Problem solved! now I still have this annoying rattle right next to my shifter. havent thought of a fix yet Link to comment Share on other sites More sharing options...
loopless Posted September 13, 2010 Share Posted September 13, 2010 My trick for the dash rattle is to go to home depot or ACE and go to the caulking section. Find some "filler" foam rope, about 1/2" diameter. Stuff that down between your windscreen and the dash,and up near the a-pillar. You can make it pretty well invisible and it pushes in nicely , then expands. Worked for me ( after 50K miles of rattle hell) e.g. http://www.acehardware.com/product/index.jsp?productId=1289225&CAWELAID=109362167 Link to comment Share on other sites More sharing options...
loopless Posted September 13, 2010 Share Posted September 13, 2010 just as a pedantic aside, this stuff is called BSR in the auto industry (Buzz/Squeak/Rattle),and costs them millions and is usually the #1 complaint. Link to comment Share on other sites More sharing options...
Phila Posted September 14, 2010 Share Posted September 14, 2010 Does anyone know how the disassemble the B-pillar? It looks like it just pops off, but I wanted to ask first before I broke anything. Link to comment Share on other sites More sharing options...
Rimfaxe Posted September 14, 2010 Share Posted September 14, 2010 I thought the dash rattle was a 'feature' of the Subaru Legacy. Seriously, I fixed the rattle in the dash near the drivers side in about 10 minutes. There's a walk through somewhere on this site. I haven't had a problem since. Link to comment Share on other sites More sharing options...
discojon Posted February 18, 2016 Share Posted February 18, 2016 Hate to resurrect this but my car is in for the takata airbag insulator install and the dash is out. I have provided the Service Writer with the Rattle TSB and she is not going to charge labor since the dash is out but wants $45 dollars for the 3 longer screws called for. Maybe I'm just being an asshole but I don't feel like I should have to pay anything. I'll pony up a few bucks for screws but $45, come on. I've been told ,"It will be less that $45" but every time I ask for an actual number, I get attitude and "I'll call you back". Update: Just got a call from her saying they had begun putting the dash back together, without doing the TSB. She stated that the technician had begun putting the dash back in since he thought I didn't want to pay the "less than $45" fee. I explained to her that I had been waiting on her to call me with an actual number and not that BS, and also that I had not talked to the tech, she passed the information along. When pressed about the actual cost she informed me is would be $48.50. I'm now contacting the regional rep and will be speaking with the dealership manager. Link to comment Share on other sites More sharing options...
Rhitter Posted February 18, 2016 Share Posted February 18, 2016 That's great to know that they will do it. Even if it is ridiculously priced. I'll have to bring this in when I do the airbag recall. My Dash has been rattling like crazy.It's separated so much the dash rattle stoppers no longer work. My OBXT build Link to comment Share on other sites More sharing options...
discojon Posted February 18, 2016 Share Posted February 18, 2016 Well, the issue is they didn't do it. The Service Writer wouldn't give me a price and told the tech to put the car back together without ever notifying me. The last I knew I was waiting on a price, then I get a call saying the dash is going back in. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 19, 2016 Share Posted February 19, 2016 I was told to fix the dash rattle while the air bag recall is being done, is a five hour job. I just picked my wagon up from having the air replaced and drove it 140 miles and the dash made no noise. Tomorrow it will 6F when I leave to go skiing, I'll see if it rattles. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
