Skyguardian Posted August 16, 2010 Share Posted August 16, 2010 I installed my zero/sports front and rear sway bars yesterday along with the kartboy F / R endlinks and avo stout mounts. Kartboy provides and aluminium spacer for the front endlinks so they can be totally vertical and not with a slight angle. But when I put the spacers on ( on the lower bolt ) , the endlinks are vertical but very close to the swaybar and I'm affraid that the sway will not clear the screw/bolt under load. So I decided to install the endlinks without this spacer. You can see that it puts more stress on the bushings but theres plenty of clearance for the bar. The question is : did you guys installed this spacer or not ? If not, your bushings on the endlinks are holding up well without breaking ? Thanks ! http://i52.photobucket.com/albums/g11/sentragxe2001/rsz_img_0588.jpg Link to comment Share on other sites More sharing options...
snow05gtRI Posted August 16, 2010 Share Posted August 16, 2010 i don't think I had any spacer with mine. I believe they are angled. Link to comment Share on other sites More sharing options...
Skyguardian Posted August 18, 2010 Author Share Posted August 18, 2010 thanks ! any other opinions ?! Link to comment Share on other sites More sharing options...
ProjectSega Posted September 7, 2010 Share Posted September 7, 2010 I think the spacers are for ppl that have Whiteline sway bars. Link to comment Share on other sites More sharing options...
wpmarky Posted September 7, 2010 Share Posted September 7, 2010 We just installed the same endlinks on a 25mm perrin RSB, and needed teh spacer. The spacer was needed on the swaybar connection i believe so that the other side of the endlink can reach the chasis mount. Link to comment Share on other sites More sharing options...
leftcoast74 Posted September 9, 2010 Share Posted September 9, 2010 I will b installing a Perrin 25mm fsb w/kartboy el's this weekend. I'll let u know how it goes. I have a Perrin 25mm rsb w/KB endlinks. I have it on the stiffer setting and the spacer goes inbetween the EL & the chasis mount. Link to comment Share on other sites More sharing options...
Skyguardian Posted September 9, 2010 Author Share Posted September 9, 2010 We just installed the same endlinks on a 25mm perrin RSB, and needed teh spacer. The spacer was needed on the swaybar connection i believe so that the other side of the endlink can reach the chasis mount. Thanks for the input !! I didn't had to put them on on my setup to make the connection but my endlinks were not totally straight when the car was under load ( yeah I did put a load on the suspension with jacks when I installed them ). So I ended up using these big spacers on the lower bolt of the endlinks and a few 3/8 '' washers ( 2 or 3 I believe ) on the upper bolt and it helped a lot. Still a smalllll angle but its way better than it was. Link to comment Share on other sites More sharing options...
Skyguardian Posted September 9, 2010 Author Share Posted September 9, 2010 I will b installing a Perrin 25mm fsb w/kartboy el's this weekend. I'll let u know how it goes. thanks ! Link to comment Share on other sites More sharing options...
leftcoast74 Posted September 12, 2010 Share Posted September 12, 2010 Ok, mine went on very smoothly. I have the Perrin 25mm sb, and the spacers went in the same spot, in between the el and the control arm. If u put it on the softer setting i believe the spacer goes on the top, in between the sb and el. Great upgrade. D :-$ And yes , it's alot easier 2 line them up under load. I had mine on ramps. Link to comment Share on other sites More sharing options...
