PCV hose routing
im in the middle of finishing my engine build and ive come to a road block. all the junk on top of the motor has to go back together but i cant figgure out which pcv hose goes where. a diagram or pictures would be great. the haynes manual just doesnt cut it
a lot of the routing is shown on the inside of the hood. other than this do a search for vacation pix and look for emissions etc. Will try to get link and forward it to you.
O.
Do a search for Crawford AOS (air oil seperator) there was also a post here a couple of weeks ago with a good picture. Try the powertrain forums
Engine Build - Click Here
thanks. it helped a bit. im still trying to figgure out where the lines that go right over the coolant crossover go to and the connections on the valve cover. hardest part about assembling this engine hands down has to be this mess under the intake manifold ..lol
