el scorcho Posted August 5, 2010 Share Posted August 5, 2010 I also posted this in the Warranty/problems forum, but maybe I'll get a quicker response here... 06 LGT 5MT I stick in my key, push in the clutch, turn key and all I get is this rapid succession of clicks...kind of like those automatic bb guns at carnivals... bad starter? Link to comment Share on other sites More sharing options...
DrSpeed Posted August 5, 2010 Share Posted August 5, 2010 Low battery. Solenoid is working, but can't engage starter motor. Get new battery. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
el scorcho Posted August 5, 2010 Author Share Posted August 5, 2010 is that the case even though my lights/radio are working? Link to comment Share on other sites More sharing options...
DrSpeed Posted August 5, 2010 Share Posted August 5, 2010 yep, you may have just enough juice to run the accessories. It's not completely dead, as you are running the solenoid...that's what is clicking. Jump start it, and that'll show that you need a new battery. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
el scorcho Posted August 5, 2010 Author Share Posted August 5, 2010 ah k...thanks! Link to comment Share on other sites More sharing options...
elib Posted August 7, 2010 Share Posted August 7, 2010 Jump start it he said press in the clutch, why bother with cables when you can bump it? Hope your parked on a hill! Link to comment Share on other sites More sharing options...
DrSpeed Posted August 12, 2010 Share Posted August 12, 2010 he said press in the clutch, why bother with cables when you can bump it? Hope your parked on a hill! To prove the battery is dead. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
zmarko Posted August 12, 2010 Share Posted August 12, 2010 So what was/is it OP? Link to comment Share on other sites More sharing options...
jt51 Posted October 9, 2010 Share Posted October 9, 2010 Went out tonight to start my 2005 Legacy, dead, nothing, remote did not work, no lights, nothing. Battery is 18 months old. No warning at all, usually with dead battery, you have something, but this is completely dead, any suggestions. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted October 9, 2010 Share Posted October 9, 2010 get a new battery Link to comment Share on other sites More sharing options...
jt51 Posted October 10, 2010 Share Posted October 10, 2010 My bad, guess I should have said, any suggestions since it is a fairly new battery. Link to comment Share on other sites More sharing options...
Heedz Posted October 10, 2010 Share Posted October 10, 2010 My bad, guess I should have said, any suggestions since it is a fairly new battery. still get a new battery would be the answer. optima? Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 10, 2010 Share Posted October 10, 2010 Ride the bus? If you don't want to get a new battery, the car isn't going to move on its own anytime soon... [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
jt51 Posted October 10, 2010 Share Posted October 10, 2010 Don't believe it's the battery, started it from a battery jump starter, something is draining the battery. After starting the car, you can hear an occasional noise in the dash, at first sounded like CD changer, was going. Don't know, it is going into the shop tomorrow. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted October 11, 2010 Share Posted October 11, 2010 100 bucks says its the battery Link to comment Share on other sites More sharing options...
robbie_R Posted October 11, 2010 Share Posted October 11, 2010 Maybe left a map light on? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 13, 2010 Share Posted October 13, 2010 Maybe left a map light on? ^ which I just did!!! :mad: completely emptied the battery. But jump-started and woop she goes edit: wait, isn't there some kind of settings that you use in order for these lights to turn off after a set time to avoid emptying the battery? Link to comment Share on other sites More sharing options...
Kodax Posted October 14, 2010 Share Posted October 14, 2010 ^ which I just did!!! :mad: completely emptied the battery. But jump-started and woop she goes edit: wait, isn't there some kind of settings that you use in order for these lights to turn off after a set time to avoid emptying the battery? I know my legacy (2009), it will automatically turn off all the lights in the car when the engine is turned off. Not sure about the earlier years. Link to comment Share on other sites More sharing options...
jt51 Posted October 15, 2010 Share Posted October 15, 2010 It was the one year old Subaru battery, replaced under the Subaru 30 month free replacement policy. The noise from the CD player, was, as the tech said, "cycling thru" normal when power restored. While getting battery replaced, I mentioned oil under the front, turned out to be steering rack and oil pump. Both are being replaced today. Link to comment Share on other sites More sharing options...
