Darkebane Posted August 5, 2010 Share Posted August 5, 2010 Im changing the water pump on my 97v LGT 2.5. And was wondering if anyone knows 100% for sure which way to loosen the bolt that goes through the centre of the crank pulley. Link to comment Share on other sites More sharing options...
amp27 Posted August 5, 2010 Share Posted August 5, 2010 im 50 percent sure its left. the other 50 is right i think. Link to comment Share on other sites More sharing options...
worknlikeadog Posted August 5, 2010 Share Posted August 5, 2010 hahaha Link to comment Share on other sites More sharing options...
kaz98gt Posted August 5, 2010 Share Posted August 5, 2010 EXCELLENT IDEA: I did this when I changed my timing belt: Take a really long extension to the half inch drive you have, or some kind of metal piping that will go around it. I think the bolt is a 22mm (don't quote me on it), but once you fit the socket to it, lay the extension against the frame somewhere. The bolt comes off normally, so lefty loosey. The pulley rotates to the right, so if you have the extension pinned to the frame, click the starter. That bolt will loosen right up, but DON'T HOLD THE STARTER. Coolest way to get a bolt off Link to comment Share on other sites More sharing options...
Darkebane Posted August 5, 2010 Author Share Posted August 5, 2010 EXCELLENT IDEA: I did this when I changed my timing belt: Take a really long extension to the half inch drive you have, or some kind of metal piping that will go around it. I think the bolt is a 22mm (don't quote me on it), but once you fit the socket to it, lay the extension against the frame somewhere. The bolt comes off normally, so lefty loosey. The pulley rotates to the right, so if you have the extension pinned to the frame, click the starter. That bolt will loosen right up, but DON'T HOLD THE STARTER. Coolest way to get a bolt off Tried that....broke 3 1/2" breaker bars lmao.... Ended up using a tool a local subaru guru lent me to hold the crank pulley, while i had a buddy with a 4ft pipe on the end of a 2ft 1" breaker bar...it came loose but dayum was that thing on there.. Link to comment Share on other sites More sharing options...
amp27 Posted August 6, 2010 Share Posted August 6, 2010 lmao this stuff is funny Link to comment Share on other sites More sharing options...
kaz98gt Posted August 6, 2010 Share Posted August 6, 2010 Tried that....broke 3 1/2" breaker bars lmao.... Ended up using a tool a local subaru guru lent me to hold the crank pulley, while i had a buddy with a 4ft pipe on the end of a 2ft 1" breaker bar...it came loose but dayum was that thing on there.. holy shit. you actually broke the breaker bar?? Link to comment Share on other sites More sharing options...
amp27 Posted August 6, 2010 Share Posted August 6, 2010 only the best for our nuts, right? Link to comment Share on other sites More sharing options...
Darkebane Posted August 7, 2010 Author Share Posted August 7, 2010 holy shit. you actually broke the breaker bar?? yeah it was on there for sure... Link to comment Share on other sites More sharing options...
kaz98gt Posted August 9, 2010 Share Posted August 9, 2010 you ever figure out a way to get it off? Link to comment Share on other sites More sharing options...
Darkebane Posted August 12, 2010 Author Share Posted August 12, 2010 Used a tool that a local subaru guru made, and had two people on it. One with a new(1/2") breaker bar with a 4ft pipe on the end. And me on the crank pulley tool. Took alot of strength from both of us but eventually it snapped free. We figure we broke the bolt torque at ~400ft lbs.... Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted August 12, 2010 Share Posted August 12, 2010 makes me terrified of getting the cam gears off to do a head gasket change :/ Link to comment Share on other sites More sharing options...
sleeper8406 Posted August 12, 2010 Share Posted August 12, 2010 Did you try PB blaster...or is that a bad idea? Link to comment Share on other sites More sharing options...
Osei Posted August 14, 2010 Share Posted August 14, 2010 makes me terrified of getting the cam gears off to do a head gasket change :/ You don't need to take the cam gears off to do a head gasket. The heads come off enbloc. O. Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted August 15, 2010 Share Posted August 15, 2010 I used a breaker bar, had it laying where the radiator supports to(radiator was out since im doing head gaskets) and just crank the engine but make sure your plugs are not connected to the coil. One crank of the starter and it loosened, then i took it off with a 1/2inch drive snap-on ratchet. I got to borrow a whole set of snap on and craftsman tools from my friends . Rest of the pulleys i used a 125psi compressor and a cheap impact wrench, the dewalt battery one didn't work at all. Got the head gaskets out in one day of work from 10:30am to like 6:00pm. First time ever taking an engine apart, especially taking the camshafts out. Link to comment Share on other sites More sharing options...
subikid90 Posted August 15, 2010 Share Posted August 15, 2010 How the gaskets look? Any signs of them leaking? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
