youknowit Posted July 29, 2010 Share Posted July 29, 2010 When should I/have someone else change my spark plugs and how long does the ATF fluid usually last? I think im worried about the ATF then anything...I really dont want this tranny to take a shit. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 29, 2010 Share Posted July 29, 2010 Plugs at 60,000 miles. Read the owners manual for recommended ATF changes. It's all in there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dvran Posted July 30, 2010 Share Posted July 30, 2010 Every 30K for the transmission oil changes. I do mine at 40K because I mainly have highway miles. I changed my plugs out myself at 60K miles. NGK Iriduim. Link to comment Share on other sites More sharing options...
Strizzy Posted July 30, 2010 Share Posted July 30, 2010 I changed my plugs at 30k miles. Pretty easy to do with a short socket extension and swivel attachment. Took about a good hour taking my time. Removing the air pump on the drivers' side makes things a bit easier. I'm pretty sure Subaru updated the service interval for the plugs for 08+. This applied to all LGTs. My bad luck build Link to comment Share on other sites More sharing options...
boymk123 Posted July 31, 2010 Share Posted July 31, 2010 both 30k Link to comment Share on other sites More sharing options...
youknowit Posted August 9, 2010 Author Share Posted August 9, 2010 Done and Done and I also got my coolant changed...all for only $388.20 (I know i couldve done the plugs myself but i just dont have resources to do it) Link to comment Share on other sites More sharing options...
