wpmarky Posted July 6, 2010 Share Posted July 6, 2010 So I've gotten tuned for stage 2 already. If I get an aftermarket TMIC will I need a new tune? Or can i just continue to use my previous stg. 2 tune and wait until I get more stage 3 parts to get tuned? Link to comment Share on other sites More sharing options...
Th3Franz Posted July 6, 2010 Share Posted July 6, 2010 You can wait to get tuned. I did and consistently logged the car and it was fine. You'll get more gains with the tune of course since you can add timing with a bigger intercooler -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
wpmarky Posted July 6, 2010 Author Share Posted July 6, 2010 Kool, thanks that's what I was hoping that a re-tune would just add gain, but i wasn't sure the TMIC would change airflow or pressure buildup. Link to comment Share on other sites More sharing options...
Spec B Posted July 6, 2010 Share Posted July 6, 2010 One thing I would look out for is overboost with the bigger TMIC, other than that it is fine. Link to comment Share on other sites More sharing options...
f1anatic Posted July 11, 2010 Share Posted July 11, 2010 Normally I'd say NO but experience told me otherwise. I was fine with the first pro-tune following my 2009 install of a Perrin TMIC in May but by July when the hot weather came, I started knocking and I needed another pro-tune. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted July 12, 2010 Share Posted July 12, 2010 Don't just install it and go. Take some logs. In my experience with the Perrin TMIC, the WOT AFR did change. On the search for a new DD... Link to comment Share on other sites More sharing options...
thefoos Posted July 12, 2010 Share Posted July 12, 2010 ^That certainly can occur if you are now in load sites that were previously untuned... Link to comment Share on other sites More sharing options...
f1anatic Posted July 12, 2010 Share Posted July 12, 2010 Don't just install it and go. Take some logs. In my experience with the Perrin TMIC, the WOT AFR did change. ^That certainly can occur if you are now in load sites that were previously untuned... Wisdom says that. But I was light knocking (-1 to -3) while cruising or even at idle. Not at WOT. Go figure. Link to comment Share on other sites More sharing options...
GTTuner Posted July 12, 2010 Share Posted July 12, 2010 Hell, we need tunes for different brands of oil. I added the Perrin TM after the 18g went in and I had some knock. The front mount didn't cause any knock though. Link to comment Share on other sites More sharing options...
wpmarky Posted July 12, 2010 Author Share Posted July 12, 2010 I went the safe route and ordered a tune update from Infamous1. Got the new map today, can't wait to get this thing running! Link to comment Share on other sites More sharing options...
GTTuner Posted July 12, 2010 Share Posted July 12, 2010 Whats the temp over there this time of year? Link to comment Share on other sites More sharing options...
wpmarky Posted July 13, 2010 Author Share Posted July 13, 2010 High of 72 today, 3 weeks ago it reached 100 on the weekend. Didn't last very long tho. Link to comment Share on other sites More sharing options...
GTTuner Posted July 13, 2010 Share Posted July 13, 2010 You might want to make an IC sprayer (water), works great in hot climates. I used the passenger washer nozzle and mounted it upside down in the scoop airfoil. Link to comment Share on other sites More sharing options...
Th3Franz Posted July 14, 2010 Share Posted July 14, 2010 A sprayer is on my list. I helped a buddy with his car and he has a JDM sprayer tank we are going to try fitting in my car's trunk for the sprayer setup. I might use it to supply the windshield sprayer too lol In my experience, 99% of knock at cruise or idle is false knock. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
wpmarky Posted July 14, 2010 Author Share Posted July 14, 2010 You might want to make an IC sprayer (water), works great in hot climates. I used the passenger washer nozzle and mounted it upside down in the scoop airfoil. Interesting, is it easily reversible? Could i mount them upside down for track day, then just put them back to normal afterwards? Cooling is a concern for me, as the tracks here are in the middle of nowhere and reach 100+ easily before noon. Link to comment Share on other sites More sharing options...
