frank_ster Posted March 27, 2013 Author Share Posted March 27, 2013 to answer questions about this swap wiring is easy actually.. a 12 foot long pigtail from megasquirt is 70 $ about. all the wires are labeled. needs about 10-12 wires to make the engine run. a few extras to make the stock dash work. it took me a bit to figure things out to make the stock ecm happy. for a gutted car it would be simple as any engine mine mpgs are the same as it was with the 2.5gt engine. power output probably 650 hp at 20-25 lbs boost. and little over 700 ft lbs tq. the engine is a 200$ engine, pistons 400$ head gaskets 160 $ and a cam 270$ valve springs 80$ megasquirt 1 is enough to run as fast as you could ever want. 157$ for the kit that needs to be soldered together ~250$ for a ready to go kit. other than that the headers and up pipe need to be fabricated. and the subaru accessorys are used Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
SCHM1AN Posted March 27, 2013 Share Posted March 27, 2013 That sounds like a real option for when *knock on wood* the engine goes Link to comment Share on other sites More sharing options...
frank_ster Posted March 27, 2013 Author Share Posted March 27, 2013 ^ well i did it because mine went. i fixed it and then it went again because of other issues. at 30+ hour rebuild time i was not having fun.. so it was go to a junk yard and get a used one for 3k$ + or put some thing that i know was good and easy as shit to repair. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
05LGTLtd Posted March 27, 2013 Share Posted March 27, 2013 power output probably 650 hp at 20-25 lbs boost. and little over 700 ft lbs tq. That has to be a record holder on the 5eat, right? All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
SCHM1AN Posted March 27, 2013 Share Posted March 27, 2013 I believe frank_ster has the F1 VB installed, so it's capable of holding more power/torque than the stock trans Link to comment Share on other sites More sharing options...
frank_ster Posted March 27, 2013 Author Share Posted March 27, 2013 4th and 5th can't currently hold anything more than 14 lbs boost. i'll have to pull it apart and add clutches. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 27, 2013 Share Posted March 27, 2013 Power record most likely still goes to FRKevin, who has F1 VB, built transmission from IPT, a GT40r on E85, and no slipping. Just visited Frank_ster again couple days ago; car is awesome! [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
frank_ster Posted March 28, 2013 Author Share Posted March 28, 2013 (edited) ^ how much power was he making ? edit : looks like 500 whp ,, mine easily makes 450 ft lbs torque at 14 lbs boost from 3000 rpm to about 5000. the 2.5 gt with the gt 40 turbo has the advantage of being able to rev a reving motor can make more hp with less torque. and torque the limiting factor for trans missions not rpm. so its almost like comparing a diesel to a motorcycle engine. Edited March 28, 2013 by frank_ster Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 28, 2013 Share Posted March 28, 2013 ^ how much power was he making ? edit : looks like 500 whp ,, mine easily makes 450 ft lbs torque at 14 lbs boost from 3000 rpm to about 5000. the 2.5 gt with the gt 40 turbo has the advantage of being able to rev a reving motor can make more hp with less torque. and torque the limiting factor for trans missions not rpm. so its almost like comparing a diesel to a motorcycle engine. He can spool it up at the top of 3rd, then be able to shift into 4th and 5th, full boost. In that situation (regarding 4th and 5th) it's more of a fair comparison. However, I agree with you that you can make a lot more torque than he can at highway speeds in 4th and 5th, so that could be it. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
frank_ster Posted April 8, 2013 Author Share Posted April 8, 2013 i'm really thinking about going water to air intercooler.. main reason is the front mount intercooler restricts a lot of air flow to the a/c and engine rad. a water to air radiator with the same surface area and same effective cooling capability would be about 1/3 rd the size. would make the front bumper sit nicer with the fog lights back in and the charge pipes would be a bit nicer. and i already have the water to air intercooler and pump. and the a/c cooled water has always been a intriguing thing for me .. Next week end i'm gonna pull it in for spring servicing, i got thinner head gaskets to improve the quench gap and raise the compression a bit for better idle, low end and hope fully economy. the headers and up pipe i will header wrap to get the under hood temps down. my up pipe has a crack in it so i will weld it up. ( at the time when i made it i used mig and ground down instead of tig with the correct stainless filler.) and i have a revision to my motor mounts currently poly urethane its a bit stiff it sends some vibration into the car, so i'm actually using cavalier table bushings for 7$ each as motor mounts in this new revision. if i have extra time i will put the propane tank in run a few lines to the front and start testing with that. and if i have a lot of extra time i want to make a couple exhaust butterflys i want to block one muffler 95% and the other about 60%, i want it quieter if i can do it. the butterflys will be either boost or vacuum actuated so at wot or 5 lbs boost they will open up. the head gaskets change will be about an hour job its so easy on a push rod engine and the rest be a few more hours. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
scosocROKKER88 Posted April 8, 2013 Share Posted April 8, 2013 been following this thread... this is something else man. i'm in no way shape or form a GM man, never ever, but this is friggin cool haha Link to comment Share on other sites More sharing options...
frank_ster Posted April 12, 2013 Author Share Posted April 12, 2013 look at what i found ! corvette swaped to turbo buick engine and gets better mpg's than a v6 van. http://roguevette.com/ Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 12, 2013 Share Posted April 12, 2013 look at what i found ! corvette swaped to turbo buick engine and gets better mpg's than a v6 van. http://roguevette.com/ Yea, but how does it do in the snow? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
frank_ster Posted April 12, 2013 Author Share Posted April 12, 2013 i dont think as good as mine .. and montreal is getting 4-6 inches of snow tomorrow :D:D Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 12, 2013 Share Posted April 12, 2013 I might actually be near Montreal on business in the next few weeks. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Brprs Posted April 12, 2013 Share Posted April 12, 2013 I have a friend, whos father has a grand national v6 with a blown turbo. Boy would I love to tear it down and throw it into an older wagon. :drool: Link to comment Share on other sites More sharing options...
frank_ster Posted April 12, 2013 Author Share Posted April 12, 2013 I might actually be near Montreal on business in the next few weeks. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
frank_ster Posted April 12, 2013 Author Share Posted April 12, 2013 I have a friend, whos father has a grand national v6 with a blown turbo. Boy would I love to tear it down and throw it into an older wagon. :drool: uh change the turbo core its like 70$ and drive the gn.. get a 150$ motor from scrap yard and put in your car Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Brprs Posted April 12, 2013 Share Posted April 12, 2013 I should have been more specific. He has the engine itself and its propped up under his work bench! Link to comment Share on other sites More sharing options...
frank_ster Posted April 12, 2013 Author Share Posted April 12, 2013 well you can do that but that model is 4" longer than my front wheel drive block type. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Brprs Posted April 12, 2013 Share Posted April 12, 2013 Yeah, I figured it was. Link to comment Share on other sites More sharing options...
frank_ster Posted April 12, 2013 Author Share Posted April 12, 2013 ^ you can sell that engine for 1-2k and buy a fwd one for 150 .. so i dont see why the sad face Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
mattg Posted April 12, 2013 Share Posted April 12, 2013 That vette is bad ass. Turbo Buick for the win. Link to comment Share on other sites More sharing options...
frank_ster Posted April 12, 2013 Author Share Posted April 12, 2013 ^ yep .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
frank_ster Posted May 14, 2013 Author Share Posted May 14, 2013 updated to newest ms3 firmware! few cool new features like high power time enrichment where the car will richem up if your pulling a hill or doing a top speed run to better cool the pistons. me like Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
