Kentbox Posted June 17, 2010 Share Posted June 17, 2010 Ok, got my CAI installed and all the issues fixed. I don't notice a big difference, but it sounds great at high RPMs. Anyway, if I just tap the throttle in neutral, it sputters or hesitates, almost hiccups, then smoothly revs up. Any ideas? Link to comment Share on other sites More sharing options...
fwa2500 Posted June 17, 2010 Share Posted June 17, 2010 did you re-set the ecu? also, another topic wasnt really nessicary Link to comment Share on other sites More sharing options...
Zues Marine Posted June 17, 2010 Share Posted June 17, 2010 also, another topic wasnt really nessicary been happening alot lately Link to comment Share on other sites More sharing options...
whos_that_guy Posted June 17, 2010 Share Posted June 17, 2010 one of your vacuum line isnt hooked up, they ALL need to be hooked up even if they didnt send u an extra hose to, happened to me once Link to comment Share on other sites More sharing options...
Kentbox Posted July 1, 2010 Author Share Posted July 1, 2010 Alright, all my vacuum hoses are fine, and I reset my ecu by disconnecting the battery. Now my car idles around 6-700 RPM, and occasionally spikes up to 1700 for a couple seconds, then back down to almost a stall every now and then. Acceleration is choopy sometimes as well. Any ideas? Link to comment Share on other sites More sharing options...
Reuben Posted July 1, 2010 Share Posted July 1, 2010 Welcome to the world of f***ing u... er.. Modifying your car. Link to comment Share on other sites More sharing options...
Kentbox Posted July 1, 2010 Author Share Posted July 1, 2010 So I guess I should just put the stock airbox back on? Link to comment Share on other sites More sharing options...
Darkebane Posted July 1, 2010 Share Posted July 1, 2010 I had a similar sounding problem, changed the fuel filter, and pcv valve and worked fine after... Link to comment Share on other sites More sharing options...
one bad bg Posted July 1, 2010 Share Posted July 1, 2010 and pcv valve and worked fine after... im having a retard moment cause i have a turbo car now. what the hell is the purpose of a pcv valve on a N/A car. Link to comment Share on other sites More sharing options...
Baddog Posted July 1, 2010 Share Posted July 1, 2010 im having a retard moment cause i have a turbo car now. what the hell is the purpose of a pcv valve on a N/A car. What do you drive now? Link to comment Share on other sites More sharing options...
fwa2500 Posted July 1, 2010 Share Posted July 1, 2010 read this http://forums.nasioc.com/forums/showthread.php?t=1471819 Link to comment Share on other sites More sharing options...
Baddog Posted July 1, 2010 Share Posted July 1, 2010 read this http://forums.nasioc.com/forums/showthread.php?t=1471819 So no easy way to fix it without going back with something that is like stock it seems like. Link to comment Share on other sites More sharing options...
98quiksilvergt Posted July 1, 2010 Share Posted July 1, 2010 Pcv is for venting your crank case. You need it. N/A or not. You could just let it vent into the atmosphere, but then you would likely have oil everywhere. The valve helps to keep oil from getting into your intake. Link to comment Share on other sites More sharing options...
98quiksilvergt Posted July 1, 2010 Share Posted July 1, 2010 Kentbox, Put your stock stuff back on and see if it fixes the problem. Also make sure you don't have any air leaks between the air flow sensor and throttle body. Alot of people have cai's with no issues. Probably just something simple that you may have over looked. Link to comment Share on other sites More sharing options...
amp27 Posted July 1, 2010 Share Posted July 1, 2010 yes very simple. like putting on the vacuum hose backwards(the one for the brake booster) and backing into tree. and about that noise about cia and MAFv spikes. i really do think thats not a problem in our cars. cause most people get no problems or anything like what they are talking about. black smoke. boging. cutting out. i took mine out and my motor rips right from idle. Link to comment Share on other sites More sharing options...
Baddog Posted July 1, 2010 Share Posted July 1, 2010 I have the issue on launch too with my cone filter. I plan on replacing the ribbed piping with a polished piece from cosmo racing. Link to comment Share on other sites More sharing options...
amp27 Posted July 1, 2010 Share Posted July 1, 2010 if you could see how i hacked up the stock intake to avoid hydro lock you would be shocked cause i dont have any bog. infact it feels like i have more low end power. Link to comment Share on other sites More sharing options...
Baddog Posted July 1, 2010 Share Posted July 1, 2010 I'm not worried about hydro locking. If it did I would just put $400 into an EJ25. Link to comment Share on other sites More sharing options...
amp27 Posted July 1, 2010 Share Posted July 1, 2010 o yea true. haha they dont hydro lock it seems. mine just messed with the maf and the coil pack some how got messed up. ran on 2 cylinders(motor had zero power and sounded like a 2 cylinder engine.) Link to comment Share on other sites More sharing options...
one bad bg Posted July 1, 2010 Share Posted July 1, 2010 What do you drive now? xr4ti Link to comment Share on other sites More sharing options...
fwa2500 Posted July 1, 2010 Share Posted July 1, 2010 i made a hybrid intake and it works great, my execution of it looks kinda bad, but i promise the functionality is much better than stock. i wouldnt say there is any more power, but response is definitely better. http://img26.imageshack.us/img26/9090/img0950o.jpg Link to comment Share on other sites More sharing options...
one bad bg Posted July 2, 2010 Share Posted July 2, 2010 i see a snorkus that needs to be removed^ Link to comment Share on other sites More sharing options...
fwa2500 Posted July 2, 2010 Share Posted July 2, 2010 no, that just puts it back how it was before and defeats the whole point of it. read the thread i posted a link to i ran without the snorkus for a while and all that did was make a seriously annoying hum while not really doing anything else. with the hybrid intake i have noticed much better response and no annoying hum. Link to comment Share on other sites More sharing options...
Baddog Posted July 2, 2010 Share Posted July 2, 2010 i made a hybrid intake and it works great, my execution of it looks kinda bad, but i promise the functionality is much better than stock. i wouldnt say there is any more power, but response is definitely better. http://img26.imageshack.us/img26/9090/img0950o.jpg Panel filter in there? or do you fit a cone in there? Link to comment Share on other sites More sharing options...
fwa2500 Posted July 2, 2010 Share Posted July 2, 2010 hybrid uses the stock filter box and resonator with 3" pipes replacing the stock pipes and "torque box". its all right there in that link i posted lol here it is again: http://forums.nasioc.com/forums/showthread.php?t=1471819 Link to comment Share on other sites More sharing options...
