carr80 Posted June 11, 2010 Share Posted June 11, 2010 05 Legacy GT getting ready to go Stg2. I have a catless UP/DP and am getting an Accessport. My question is what do i need to do to prevent the CEL from coming on? 1) The UP i know there is a "resistor" fix for. Can somebody tell me what resistor i need and does it just go in where i unplug the stock egt sensor? 2) for the DP is there an "electric" fix and a "mechanical" fix? For the mechanical fix i just use the spark plug foulers right? If so what size do i need? I had a buddy with an 02 WRX and went catless and he had something that got soldered in between the 02 sensor in the wiring. Is that the electric fix? Where can i get that? Before anyone flames me i did search and read ALOT of threads but couldn't find what i was looking for. Link to comment Share on other sites More sharing options...
Strizzy Posted June 12, 2010 Share Posted June 12, 2010 I'm pretty sure the AP disables those CELs My bad luck build Link to comment Share on other sites More sharing options...
goneskiian Posted June 12, 2010 Share Posted June 12, 2010 Before anyone flames me i did search and read ALOT of threads but couldn't find what i was looking for. Really? I found this thread with a quick search of the terms "resistor mod"... http://legacygt.com/forums/showthread.php?t=135988&highlight=resistor+mod In it LosAngelesLGT links a walkthrough he created for you... http://legacygt.com/forums/showthread.php/unofficial-05-06-lgt-2-131488.html And this thread by searching "spark plug defouler" which links you to a walkthrough of this very mod on another forum... http://legacygt.com/forums/showthread.php?t=77217&highlight=spark+plug+defouler I can, however, confirm that the COBB AccessPORT does indeed take care of any codes these modifications my cause you. Link to comment Share on other sites More sharing options...
carr80 Posted June 12, 2010 Author Share Posted June 12, 2010 I can, however, confirm that the COBB AccessPORT does indeed take care of any codes these modifications my cause you. Is there a special setting you have to use on the AP to fix them or is it automatically taken care of when u flash to stg2? Link to comment Share on other sites More sharing options...
Strizzy Posted June 12, 2010 Share Posted June 12, 2010 It's automatic with the AP My bad luck build Link to comment Share on other sites More sharing options...
2006Specb122 Posted July 25, 2012 Share Posted July 25, 2012 It's automatic with the AP I have a cobb access port and was still getting P1544 codes Check out my full story here at post #8 http://legacygt.com/forums/showthread.php/check-engine-light-help-egt-sensor-135571.html?t=135571 I think it is worth a read. I am 90% sure I've solved the issue for good by removing the EGT sensor but beware those with Accessport can STILL get a code caused by the EGT sensor. Link to comment Share on other sites More sharing options...
compsurge Posted July 25, 2012 Share Posted July 25, 2012 The EGT code can be disabled by the tuner. To make sure it never bothers you, just tape a 2.2k resistor in the plug and call it a day. Link to comment Share on other sites More sharing options...
