aaabha Posted June 10, 2010 Share Posted June 10, 2010 So my friend and I found a 93 sedan for $200. It's primered and has a fender that needs replaced, but other than that the shell is great. It comes with some ridiculous and blingin 17" rims. Those can be replaced lol So the engine is the issue. It wont crank over. There's no radiator at the moment cause the kid cut the hoses for some reason, but its in the garage. It's an auto so when you start it up it spews out transmission fluid so at least that works. The fuel pump is priming so that's good too. 2 of the spark plug wires are cooked. The other two are ok, I suppose. The coil pack must be going bad cause it only fires on cylinder two from what I can remember. We couldnt get it to turn over, but it was trying which gives me hope. Now the problem is that when we did get it to finally turn a couple times (not completely start up) it shot oil through the throttle body and all the way through the air intake tube back through the MAF sensor and out of the air filter. It was smoking out of the air filter (yes, he took the box off and replaced it with a cone filter) and at first I thought it was MAF going, but when we took the intake off we found a good amount of oil up through there. First off, does anyone know the cause of this? Do you think it'd fire if we replaced the wires, coil pack, spark plugs, radiator and transmission fluid? .... Link to comment Share on other sites More sharing options...
Legacy Wagon Posted June 10, 2010 Share Posted June 10, 2010 #1: 04-22-2010, 05:52 AM $200 Sedan Legacy Wagon http://legacygt.com/forums/../image.php?u=35366&dateline=1262713080 Title: Senior Member Location: Lakeland, FL Car: 1990 Legacy L Wagon Posts: 209 iTrader: (0) http://legacygt.com/forums/../skynetim/buttons/edit.gif http://legacygt.com/forums/../skynetim/buttons/report.gif http://legacygt.com/forums/../skynetim/misc/sendpm.gif http://legacygt.com/forums/../skynetim/misc/find.gif http://legacygt.com/forums/../skynetim/buttons/quote.gif http://legacygt.com/forums/../skynetim/buttons/qreply.gif So my friend and I found a 93 sedan for $200. It's primered and has a fender that needs replaced, but other than that the shell is great. It comes with some ridiculous and blingin 17" rims. Those can be replaced lol So the engine is the issue. It wont crank over. There's no radiator at the moment cause the kid cut the hoses for some reason, but its in the garage. It's an auto so when you start it up it spews out transmission fluid so at least that works. The fuel pump is priming so that's good too. 2 of the spark plug wires are cooked. The other two are ok, I suppose. The coil pack must be going bad cause it only fires on cylinder two from what I can remember. We couldnt get it to turn over, but it was trying which gives me hope. Now the problem is that when we did get it to finally turn a couple times (not completely start up) it shot oil through the throttle body and all the way through the air intake tube back through the MAF sensor and out of the air filter. It was smoking out of the air filter (yes, he took the box off and replaced it with a cone filter) and at first I thought it was MAF going, but when we took the intake off we found a good amount of oil up through there. First off, does anyone know the cause of this? Do you think it'd fire if we replaced the wires, coil pack, spark plugs, radiator and transmission fluid? -------------------------------------------------------------------------------------------------------------------- Looked familiar. Is our board messing up or is someone being dumb? Link to comment Share on other sites More sharing options...
SiRiS Posted June 10, 2010 Share Posted June 10, 2010 i think it will need an engine. they are a buck and a quarter here but can range up to a grand some places. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted June 10, 2010 Share Posted June 10, 2010 Nah, this thread is old. I made it back in April. We didnt get the car. I just dont know why it was reposted yesterday by someone who wasnt me. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted June 12, 2010 Share Posted June 12, 2010 WTF????? I was going to say that this post sounds familiar, but then I read the replies. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted June 14, 2010 Share Posted June 14, 2010 XD Yeah, a bit weird. Never got a clear cut explanation on it either haha Link to comment Share on other sites More sharing options...
