Gmachine Posted June 14, 2010 Share Posted June 14, 2010 Hi Gmachine, I'm thinking of getting 1 set of KTA124 but it cost 600+++ in SG. Is it good? Worth installing? Hello there,,,,,,, Excuse my ignorance,but i do not know what SG stands for. $600.00 US would be hella expensive for this. Contact Fred Beans on this forum for a good price. As for the parts they are are made well and fit perfect. Whether you need these parts,depends on what you have done to your car and how you are using it. Link to comment Share on other sites More sharing options...
earth Posted June 15, 2010 Share Posted June 15, 2010 Thanks for the quick reply. SG is Singapore in short. =) I'll be getting KTA313 and KTA124. Getting KW V2 coilovers as current tein monoflex are making irritaing noise. Tein used to make very good coilovers and long lasting but not anymore... Sigh... Link to comment Share on other sites More sharing options...
fixem2r Posted June 26, 2010 Share Posted June 26, 2010 They are expensive but they save a bunch of weight. Like 7-8lbs/side if I recall correctly. Combine it with aluminum upper links and WL camber and toe links and you have... well, my suspension. I will find out if we can get these parts for you guys. http://img88.imageshack.us/img88/2976/img8202s.jpg http://img412.imageshack.us/img412/673/img8207s.jpg FBP, Any chance you can clarify what I am seeing in these pics? I can pick out the RSB, endlinks and Rear Mounts, but the other Aftermarket pcs that I see, I am not sure what they are described as. Thanks Link to comment Share on other sites More sharing options...
FredBeans Posted June 27, 2010 Share Posted June 27, 2010 http://img192.imageshack.us/img192/2976/img8202s.jpg http://img138.imageshack.us/img138/2707/img8207sp.jpg There you go sir. That is the best I can do pre-coffee and without a mouse. Here is my full mod list: http://legacygt.com/forums/showpost.php?p=821157&postcount=1 Link to comment Share on other sites More sharing options...
fixem2r Posted June 28, 2010 Share Posted June 28, 2010 That is perfect and exactly what I was looking for. Greatly appreciate the work! Link to comment Share on other sites More sharing options...
naimouasta Posted August 11, 2010 Share Posted August 11, 2010 Okay, so just to be clear: http://www.whiteline.com.au/Plus/part_images_new/thumbs/tn_W63217.jpg W63217 is the front bushing for the rear trailing arm. http://www.whiteline.com.au/Plus/part_images_new/thumbs/tn_W63225.jpg W63225 are replacement bushings for the upper control arm. I can't quite discern where W93230 and W93231 go. How do these compare to the normal KDT903 that some people have used (diff inserts)? so are these still in development or are they not available anymore? Link to comment Share on other sites More sharing options...
grmorrow04 Posted August 25, 2010 Share Posted August 25, 2010 Any updates on availability of these? Link to comment Share on other sites More sharing options...
naimouasta Posted October 2, 2010 Share Posted October 2, 2010 bump? Link to comment Share on other sites More sharing options...
aussie_coyote Posted October 3, 2010 Share Posted October 3, 2010 Last time I checked, Whiteline didn't make bushes .. they bought them from Fulcrum (who have been making these parts for the BP/BL for years). Link to comment Share on other sites More sharing options...
grmorrow04 Posted October 21, 2010 Share Posted October 21, 2010 Okay, so just to be clear: http://www.whiteline.com.au/Plus/part_images_new/thumbs/tn_W63217.jpg W63217 is the front bushing for the rear trailing arm. Ok, so here's my experience with these... I tried working with a couple different vendors but nobody seemed to know/care what I was searching for. Tony at TiC ended up helping me out and did some searching for me. I wanted to upgrade to full poly where-ever I could, and have Spec B aluminum bits to install on my car, so it made sense to order everything I could. So far, the only issue I've found is with the above bushing, W63217. If you look at Whiteline Plus's website, http://www.whiteline.com.au/Plus/product_detail.php?part_number=W63217 , it says that the product will work with the following: SUBARU FORESTER SH MY05-10 (9/03-on) SUBARU IMPREZA GH HATCH, SEDAN MY08 INCL WRX & STI (9/07-on) SUBARU LIBERTY BL SEDAN, BP WAGON (LEGACY) (9/03-4/09) SUBARU OUTBACK BP MY04 -06 (9/03/2007) Going on the logic that the bushing works for MY08 WRX & STI, and switching over to the regular Whiteline site, searching for MY08 STI, you find that Whiteline lists W0568 as the rear trailing arm bushing. Following the above logic, the bushing for the MY08 STI SHOULD fit the BL rear trailing arm, right? WRONG. The bushing is too small in diameter, by about 3/8" (I don't have exact values as the stock bushings are still in place). This puts me in a dilemma as I really want to get poly for the trailing arm, and I don't want to wait another 4-6 weeks to get the damn things from Australia, especially if they end up being the wrong bushing *again*. I heard about anything else other than Group N bushings, and I can't even find the number for those. Is it just me, or does Whiteline have their fitment listing wrong? Link to comment Share on other sites More sharing options...
Leonardo Posted October 21, 2010 Share Posted October 21, 2010 interesting! Link to comment Share on other sites More sharing options...
grmorrow04 Posted October 25, 2010 Share Posted October 25, 2010 After a few emails with Whiteline, the W63217 is the same size as the W0568, measuring at 53.4mm in diameter. So no go for these. However, in the last email I got from Whiteline, one of the tech/customer support people said: "The part you need is on our development list but probably won't be available till next year." So there is hope, but we just have to wait... rather I'll just have to wait to change out the rear trailing arms! I hope this comes sooner than later! Link to comment Share on other sites More sharing options...
Leonardo Posted October 25, 2010 Share Posted October 25, 2010 If you can't wait to change the arms, get the SpecB bushings as they are stiffer than the GT ones. Link to comment Share on other sites More sharing options...
grmorrow04 Posted October 26, 2010 Share Posted October 26, 2010 Oh, I can wait... I don't have any torn bushings back there, and that's not an install I'd want to go through twice! I asked the Whiteline tech about an ETA, and he said if he had to guess, mid-year 2011. Link to comment Share on other sites More sharing options...
JohnnyT Posted October 26, 2010 Share Posted October 26, 2010 subscribed. I am getting the itch to upgrade my stock LGT suspension. I'm not very familiar with all this. I'll have to study up on it. Link to comment Share on other sites More sharing options...
turbodog Posted September 9, 2011 Share Posted September 9, 2011 Bump. Any more updates on rear whiteline bushings? Not that I'm in any hurry to install more bushings. Link to comment Share on other sites More sharing options...
naimouasta Posted December 25, 2011 Share Posted December 25, 2011 i'm bumping this thread because i think they finally came out with the parts? they have a bunch of new bushings i think and they are black, not the regular yellow. i think some of these parts are just more of a "standard" replacement. it does look like they do have the trailing arm bushing; i'm still trying to figure what bushing is what man i don't want to tear my whole suspension apart again :|. http://www.whiteline.com.au/do_segue4.php?make=Subaru&model=Legacy&model_final=LEGACY+BL+SEDAN%2C+BP+WAGON+MY04-09+INCL+TURBO&vehicle=9%2F03-8%2F09 Link to comment Share on other sites More sharing options...
Dan O Posted February 10, 2012 Share Posted February 10, 2012 i'm bumping this thread because i think they finally came out with the parts? they have a bunch of new bushings i think and they are black, not the regular yellow. i think some of these parts are just more of a "standard" replacement. it does look like they do have the trailing arm bushing; i'm still trying to figure what bushing is what man i don't want to tear my whole suspension apart again :|. http://www.whiteline.com.au/do_segue4.php?make=Subaru&model=Legacy&model_final=LEGACY+BL+SEDAN%2C+BP+WAGON+MY04-09+INCL+TURBO&vehicle=9%2F03-8%2F09 Has anybody tried or confirmed this part fits? My trailing arm bushings look as bad as my front bushings that I am replacing, I would like to replace this also. Link to comment Share on other sites More sharing options...
