colt45 Posted May 26, 2010 Share Posted May 26, 2010 so my check engine light goes on i check the gas cap still on go see the dealer he says i am pushing about 70 compression and i need a top end job question at 67000 miles insnt this early for a 2006 lgt to need this work? went to stage 2 did that cuase premature wear? i Link to comment Share on other sites More sharing options...
ktmrider Posted May 26, 2010 Share Posted May 26, 2010 search "Cracked Ring Land" and goto another stealership ASAP STG2 in itself won't cause it, use of OTS maps and/or no logging can hmm, lost some capital letters and a period or three somewhere.... Link to comment Share on other sites More sharing options...
colt45 Posted May 26, 2010 Author Share Posted May 26, 2010 did use maps why go to another stealership? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 26, 2010 Share Posted May 26, 2010 Is the stealership going to cover this. if not ask around the local repair shop's to find a good machine shop who will do the rebuilding. This is pretty much normal work and can be done by most competent repair shops. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
colt45 Posted May 26, 2010 Author Share Posted May 26, 2010 no past warranty plus i gots the mods factor just called they checked not a cracked ring hey max fellow nutmegger i see from rocky hill by way of manchester Link to comment Share on other sites More sharing options...
Max Capacity Posted May 26, 2010 Share Posted May 26, 2010 If your doing this yourself. Talk with Mark Eastwood at Eastwoods Auto Machine in Somersville. 860 749 2903 http://www.eastwoodsautomachine.com They do a lot of import work and work for a lot of dealers around here. Even dealers in Hartford send there stuff up to him. You can tell him the guy with the yellow honda civic sent you. They are old family friends. Pulling it apart, is another thing, is that something your going to do? I have a trailer if you need help moving it. I have also had good customer service from Mike at http://www.TuningAlliance.com he's in W.Springfield MA for your tuning needs. Sounds like you may have some burnt valves ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
