w00t!!11! Teh DM broke into teh 13s!!!!11one
Drift Monkey
It happened. Put the stockers back on and filled em up to 55psi all the way around..;)
Result:
R/T: .528
60': 1.966
330: 5.745
1/8: 8.898
MPH: 78.62
1000: 11.601
1/4: 13.918
MPH: 96.73
Could I have done bettAr? Probably, but I'm pretty satisified with this run since the last time I went to the strip I ran a best of 14.3xx. :gome:
Heh, NICE! It's all about strategy. The larger OD of the tires with more pressure helped I'm sure as AWD doesn't have AS much of problem hooking up with the right launch.
I gots to get my butt to the strip on one of their test and tune nights in the next month or so. :)
Very NICE times!!!! Especially for essentially being stock! Did you happen to weigh the car? What launch technique did you use? What about the track weather conditions? These all play a pivotal? part in what times a car will run any given day. It also helps us out in being able to compare times more accurately.
I didn't get t weigh the car. D'oh. I used the "thottle blip" method, bouncing between 4k and 4.5k. The track was horribly sticky last night. The weather, not so great, not nearly as cold as the last time I went, but I definately got a better launch.
64-72 degrees, but 53-88% humidity.
Yeah i'd say catless UP pipe helps out a bit and just barely squeeks you out of the "stock" catagory:redface: . Jeez some feel if you remove your spare tire your not stock anymore :lol: gimme a break. Nice times I wanted my 13.9X run but could'nt get it. Next time i'll get it without question :D .
