Strizzy Posted May 11, 2010 Share Posted May 11, 2010 http://cgi.ebay.com/ebaymotors/WRX-08-09-SRS-3-Iron-Cast-Flange-Divorce-DOWNPIPE-NEW-/360226219567?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item53df27e62f Found this on eBay and was wondering if anyone is running it. Thoughts? I'm running an Invidia catted at the moment and looking to go catless. I was looking at going with Invidia's catless because it is a divorced flange (slightly quicker spool). I like the price too. If no one has it yet, I might be the guinea pig for this one. Anyone looking to buy a used Invidia catted dp? My bad luck build Link to comment Share on other sites More sharing options...
coldradio1 Posted May 11, 2010 Share Posted May 11, 2010 Looks good to me. Looks pretty much identical. As long as fitment is good, I say go for it. Link to comment Share on other sites More sharing options...
m sprank Posted May 12, 2010 Share Posted May 12, 2010 Why not just get an ERZ/CNT for $189. They are a forum vendor and you get real customer service with your order. Link to comment Share on other sites More sharing options...
Strizzy Posted May 12, 2010 Author Share Posted May 12, 2010 I want the divorced flange. My bad luck build Link to comment Share on other sites More sharing options...
m sprank Posted May 12, 2010 Share Posted May 12, 2010 Ok. To each his own.  Be ready to grind it down if it hits your turbo flapper.  Plus, because you dont have a twinscroll or a huge motor and turbo there is no gain to the divorcing plate. My $0.2. eBay is great, but I like to support the forum vendors too. Link to comment Share on other sites More sharing options...
Strizzy Posted May 12, 2010 Author Share Posted May 12, 2010 I've got the divorced Invidia catted and had to grind down the divider to fit. I'm hitting my peak boost around 2700-3000 rpm, and I've noticed others without a divorced flange hit peak around 3200 or so. Again, to eat his own. Though I do have plans for a larger turbo in a year or so. My bad luck build Link to comment Share on other sites More sharing options...
m sprank Posted May 12, 2010 Share Posted May 12, 2010 VF-46's hit peak boost around 2800rpm. VF-40's hit later. Its the turbo in your 08 (different housing). Not the DP. Link to comment Share on other sites More sharing options...
integroid Posted May 12, 2010 Share Posted May 12, 2010 After having to cut out almost all of the divorced section in my invidia so my wastegate flapper would open, I would never buy a divorced bellmouth again. ERZ for $189 gets my vote too. Link to comment Share on other sites More sharing options...
m sprank Posted May 12, 2010 Share Posted May 12, 2010 Thanks for the support. Hows that monsta wagon holding up? Link to comment Share on other sites More sharing options...
tjbev21 Posted May 18, 2010 Share Posted May 18, 2010 Why not just get an ERZ/CNT for $189. They are a forum vendor and you get real customer service with your order. Link to comment Share on other sites More sharing options...
NSFW Posted May 18, 2010 Share Posted May 18, 2010 That divider does look like it sticks out far enough to hit the flapper, just like the first-generation Invidia parts. Invidia's second-gen bellmouth divider sticks out about half as far (I have one - no interference). You should assume you'll have to trim it to clear. Link to comment Share on other sites More sharing options...
Strizzy Posted May 18, 2010 Author Share Posted May 18, 2010 The Invidia dp I have now, I had to trim the divider a bit to clear the flapper. I don't have a problem with trimming to fit. I'll be placing my order once I get back from Costa Rica in two weeks, so I'll keep an update. My bad luck build Link to comment Share on other sites More sharing options...
m sprank Posted May 18, 2010 Share Posted May 18, 2010 Its the same price as a ERZ??? They want $40 shipping. Link to comment Share on other sites More sharing options...
GULLABLE0NE Posted May 18, 2010 Share Posted May 18, 2010 i never had to trim my nvidia catted dp on my 08Gt, lucky i guess Link to comment Share on other sites More sharing options...
m sprank Posted May 18, 2010 Share Posted May 18, 2010 ^ v2 Link to comment Share on other sites More sharing options...
tjbev21 Posted May 18, 2010 Share Posted May 18, 2010 im with mike, you know that the ERZ/CNT DP is good quality and great fitment and awesome customer service. why risk it on some ebay vendor with a "knock off" ? when you can get the better quality for the same price. id get the divorced style out of your head, you will see no gains or faster spool with the divorced, maybe with a 20g turbo or something but id even doubt it then, until i see a side by side dynos of the same car on the same dyno, on the same day with bellmouth and divorced... just my 2 cents, its your car do what you want. Link to comment Share on other sites More sharing options...
