Pinter Posted May 10, 2010 Share Posted May 10, 2010 Hi all, I have been searching for a % number of power sent to the front or rear wheels. Like when just driving down the road, does like 100% of the power go to the rear wheels or how does it work? I searched like crazy but I guess I don't know the proper term to search for. I was testing it on the weekend and it was raining but stopped and then smashing the gas down 100%, the first time I tried it, the rear wheels were spinning for a good 5 seconds before the front kicked in and it stopped spinning but the next 5 or so times I did it, only the front wheels would spin for about 2-3 seconds before the rear tires kicked in and it stopped spinning. Also, will it be possible to do doughnuts in snow? I dunno if it makes a difference but I have a 06 limited 4 speed auto 2.5i Thanks all for your time Link to comment Share on other sites More sharing options...
nemo Posted May 10, 2010 Share Posted May 10, 2010 I believe the 5MTs are a 50/50 bias. The 4EATs are 90/10 that's continuously variable. If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
Pinter Posted May 10, 2010 Author Share Posted May 10, 2010 So only my rear wheels spinning is very weird and shouldn't have happened? Link to comment Share on other sites More sharing options...
carguyco Posted May 10, 2010 Share Posted May 10, 2010 I find it odd that you were able to spin ANY wheels continuously with a 2.5 NA Was it sleet or ice? Or plain old rain? Link to comment Share on other sites More sharing options...
Pinter Posted May 10, 2010 Author Share Posted May 10, 2010 It was just rain and the roads were slippery. The first time I tried it I was able to spin the rear wheels for atleast 5 seconds until I let off the gas but the rest of the times, it was for 3 seconds max before the rear tires started to move so the front would stop spinning. Also does it have any difference if your in sport mode or not? Link to comment Share on other sites More sharing options...
joeblow Posted May 10, 2010 Share Posted May 10, 2010 Well sport and s# will give you more throttle response and technically put a little more power to the wheels right away when you stomp on it, but you still shouldn't be able to spin the wheels on a straight drive, even in rain. The only time I can get my wheels loose in rain is on turns under acceleration. What kind of tires and tread life do you have? It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Max Capacity Posted May 10, 2010 Share Posted May 10, 2010 I like to play around like that in the dirt. You will see that all 4 spin at the same time. Even in my 00' GT and the 98' GT. All cars are 5 speeds. IMO on a rain slick road there are still varibles that you can't see. Just be happy that the AWD knows what to do. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pinter Posted May 10, 2010 Author Share Posted May 10, 2010 I just have factory tires but the car is a 06 with less then half the tread life left. I was just testing it out to see what it can do. I finally found a thread that answers everything I asked here and I wish I would have gotten a 5 speed as it seems to be 50/50 however I am happy with my choice of cars but next time if I do go auto, i will make sure it's a 5 speed auto. Thanks all Link to comment Share on other sites More sharing options...
IanB Posted May 10, 2010 Share Posted May 10, 2010 I just have factory tires but the car is a 06 with less then half the tread life left. I was just testing it out to see what it can do. I finally found a thread that answers everything I asked here and I wish I would have gotten a 5 speed as it seems to be 50/50 however I am happy with my choice of cars but next time if I do go auto, i will make sure it's a 5 speed auto. Thanks all When guys state that the "5 speed has 50/50 split", they are referring to the manual transmission. All the auto's, regardless of 4A or 5A, have the same 90/10 torque split AWD system. Only the manual transmission cars get the 50/50 AWD. Link to comment Share on other sites More sharing options...
RJS5689 Posted May 10, 2010 Share Posted May 10, 2010 When guys state that the "5 speed has 50/50 split", they are referring to the manual transmission. All the auto's, regardless of 4A or 5A, have the same 90/10 torque split AWD system. Only the manual transmission cars get the 50/50 AWD. That is wrong! 5EATs use a 45:55 split. 4EAT: 90:10 5EAT: 45:55 5MT/6MT (Spec.B): 50:50; Speb.B uses a Torsen LSD out back, instead of the viscous found in the 5MT GT. Link to comment Share on other sites More sharing options...
joeblow Posted May 10, 2010 Share Posted May 10, 2010 But in order to get the 5EAT you have to have the turbo. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
IanB Posted May 10, 2010 Share Posted May 10, 2010 That is wrong! 5EATs use a 45:55 split. 4EAT: 90:10 5EAT: 45:55 5MT/6MT (Spec.B): 50:50; Speb.B uses a Torsen LSD out back, instead of the viscous found in the 5MT GT. I stand corrected! Link to comment Share on other sites More sharing options...
Pinter Posted May 10, 2010 Author Share Posted May 10, 2010 Great info guys. Thanks again. Weird how it's different per car and transmission type. I say make it all the same and give us the configuration the STI has. Link to comment Share on other sites More sharing options...
RJS5689 Posted May 11, 2010 Share Posted May 11, 2010 Great info guys. Thanks again. Weird how it's different per car and transmission type. I say make it all the same and give us the configuration the STI has. That would be fun. I know I would certainly enjoy it. Although most people would look at it and think, "Hmm, what does all this mean?" Link to comment Share on other sites More sharing options...
joeblow Posted May 11, 2010 Share Posted May 11, 2010 Front LSD and DCCD are the two major points that stand out to me when it comes to drivetrain and power split. Anything else fun, I'd be curious to know too, I'm not overly well versed on the STi. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Strizzy Posted May 11, 2010 Share Posted May 11, 2010 I've already got a STI front LSD installed. DCCD is next on my driveline mod list. Other than that, I don't really think there is anything more than sets the STI that much apart from the LGT. There is the 6mt, but that's covered with the specB. My bad luck build Link to comment Share on other sites More sharing options...
