Zues Marine Posted May 21, 2010 Share Posted May 21, 2010 they run too much time and $$ for it to be worthwhile Link to comment Share on other sites More sharing options...
bmwpride Posted May 21, 2010 Share Posted May 21, 2010 So not worth it then? I mean i can get all the parts for cheap and or free. Still not worth it? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 21, 2010 Share Posted May 21, 2010 i dont think it is.. its going to be alot of work.. but if you have time by all means.. boost that bad boy Link to comment Share on other sites More sharing options...
bmwpride Posted May 21, 2010 Share Posted May 21, 2010 i want to im just worried that its going to take to much down time. I know i need wrx stock turbo, dp, and up pipe. Does it matter which i get. Also need a exhaust mani, does it matter sti/wrx. Also a sti or wrx intercooler. Oil lines, and tapped oil pan and or valve cover. Now what if i wanted to run a t3 with a external wastegate what would be the best way to make that happen. Also what is the main reason of swapping the subframe, what is getting in the way. Link to comment Share on other sites More sharing options...
SSpeed Posted May 21, 2010 Share Posted May 21, 2010 http://www.rs25.com/forums/f7/t84343-2-5-rs-turbo-sti-swap.html#post1424874 Link to comment Share on other sites More sharing options...
