NSFW Posted April 22, 2010 Share Posted April 22, 2010 This was in the box with my new Racingbrake rotors: http://i193.photobucket.com/albums/z151/Legacy_NSFW/Brakes/RotorRotation.jpg Is it just me, or does the rotation look backward? The vanes inside the rotors are straight. The texture on the rotor surface looks the same either direction. I don't see anything about the construction of the rotor that suggests it would matter which way the slots are oriented. So I think I'm going to mount them backward. Here's your chance to talk me out of it... Why would it matter? What should I look for, in the rotors themselves, that would indicate why it matters which side they're installed on? Link to comment Share on other sites More sharing options...
JoeFromPA Posted April 22, 2010 Share Posted April 22, 2010 It's not the external grooves that matter, it's the internal vanes. If the manufacturer says to mount them a certain way, follow that way. Don'tfollow the external vanes as a general guideline. Their orientation is fairly meaningless. Link to comment Share on other sites More sharing options...
Ridgeracer Posted April 22, 2010 Share Posted April 22, 2010 Agreed^....also if it helps my StopTechs shows the same orientation against the external grooves too... "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
NSFW Posted April 22, 2010 Author Share Posted April 22, 2010 It's not the external grooves that matter, it's the internal vanes. If the manufacturer says to mount them a certain way, follow that way. Don't follow the external vanes as a general guideline. Their orientation is fairly meaningless. Like I said in the first post, the vanes inside the rotors are straight. Link to comment Share on other sites More sharing options...
Th3Franz Posted April 22, 2010 Share Posted April 22, 2010 Generally for straight vane rotors, the inside of the slot should be first to pass across the pad... -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
NSFW Posted April 23, 2010 Author Share Posted April 23, 2010 I was going to ask RB this question via email, but it turns out that they have a forum, and they already have a thread about this. So, I asked there: http://forums.racingbrake.com/showthread.php?t=74 Link to comment Share on other sites More sharing options...
NSFW Posted April 24, 2010 Author Share Posted April 24, 2010 Racingbrake approves my plans. Turns out (pun intended) that it only really matters for their curved-vane discs. http://forums.racingbrake.com/showpost.php?p=1838&postcount=12 Link to comment Share on other sites More sharing options...
