Bassnectar Posted April 11, 2010 Share Posted April 11, 2010 since i bought some yesterday, but noticed im supposed to use automatic transmission fluid! Link to comment Share on other sites More sharing options...
Ryandigi Posted April 11, 2010 Share Posted April 11, 2010 I used mobil 1 synthetic ATF....I am sure regular stuff works fine as well Link to comment Share on other sites More sharing options...
Bassnectar Posted April 11, 2010 Author Share Posted April 11, 2010 is it fine to mix and just top up? Link to comment Share on other sites More sharing options...
kaz98gt Posted April 11, 2010 Share Posted April 11, 2010 atf is what you're supposed to use. the pwr steering and transmission both operate on the same type of fluid (can't remember what it's called now), and atf is for both applications. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted April 12, 2010 Share Posted April 12, 2010 Dexron III or Dexron IV. Castrol Multi-Import works as well. I personally wouldn't waste my money on synthetic stuff for a power steering pump, but whatever floats your boat.Mixing old and new fluid is fine. Link to comment Share on other sites More sharing options...
Bassnectar Posted April 12, 2010 Author Share Posted April 12, 2010 ah k thanks guys im pissed i grabbed a bottle of power steering fluid that is now useless, but i guess someone will eventually need it! any advantage in using dexron IV because i have some 3 at my dads Link to comment Share on other sites More sharing options...
Platinum_Racing Posted April 12, 2010 Share Posted April 12, 2010 In a transmission it can cause SLIGHTLY smoother shifting and a reduction in friction. Dexron fluids were designed by GM to be backwards compatible, meaning Dexron IV can be used in Dexron III applications, but Dexron III CANNOT be used in Dexron IV applications. In a power steering pump it probably won't make a bit of difference. If you have Dexron IV lying around pour it in and you'll be good to go. Don't worry about mixing it. Link to comment Share on other sites More sharing options...
Bassnectar Posted April 12, 2010 Author Share Posted April 12, 2010 well i have dexron 3 but ill top up with that, it seems to be leaking right under the resevoir which everyone says is common Link to comment Share on other sites More sharing options...
subikid90 Posted April 12, 2010 Share Posted April 12, 2010 well i have dexron 3 but ill top up with that, it seems to be leaking right under the resevoir which everyone says is common I have the same issue. Mine seems to be leaking from the hose. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
