Baddog Posted April 8, 2010 Share Posted April 8, 2010 I believe I read somewhere the 96 Legacy L 2.2 doesn't need valve adjustments? Well here's my issue. I keep getting a Cylinder 2 Miss-fire. Every morning now for the past few days. I installed an MSD Ignition (It did it randomly with the stocker still) and new Phase 2 Plug Wires. The Spark Plugs are only about 6k miles old. I will be going to replace them this weekend and see if it helps. After that what can I do? Link to comment Share on other sites More sharing options...
Baddog Posted April 8, 2010 Author Share Posted April 8, 2010 Also off topic from my normal question I just didn't want to make a new post. Are the Hvac controls on a 96 L supposed to light up? The ones in mine don't. Link to comment Share on other sites More sharing options...
kaz98gt Posted April 8, 2010 Share Posted April 8, 2010 ^ Yes there's a thread somewhere about this. DIY, bulbs are easy to get out and replace. saves you alot of hassle. as far as valve adjustments, do you mean the lash? I've read that the 2.2 has hlas, but I've been looking into checking mine, and it's all mlas. then again mine's from 98, so I don't know if anything had changed from there. Link to comment Share on other sites More sharing options...
kaz98gt Posted April 8, 2010 Share Posted April 8, 2010 http://legacygt.com/forums/showthread.php/change-heater-control-lights-95-26408.html?t=26408&highlight=hvac+bulbs DIY for hvac bulbs Link to comment Share on other sites More sharing options...
Baddog Posted April 8, 2010 Author Share Posted April 8, 2010 Anyone on the misfires. I think it has the lash yeah. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 9, 2010 Share Posted April 9, 2010 not all the HVACs light up, im not sure when subaru changed it but ive come across a few models whose buttons didn't light up and didn't have any bulbs spots behind them.. check it out before you buy leds! Link to comment Share on other sites More sharing options...
Baddog Posted April 9, 2010 Author Share Posted April 9, 2010 Okay sooooooo, I am still looking at options on how to clean Fuel Injectors w/o the use of Seafoam and that kind of thing. Also how do I adjust the valve lash? Link to comment Share on other sites More sharing options...
Zues Marine Posted April 9, 2010 Share Posted April 9, 2010 why dont you want to use seafoam? Link to comment Share on other sites More sharing options...
Baddog Posted April 9, 2010 Author Share Posted April 9, 2010 Already did that a few weeks ago. Now getting mis-fires more. I was told it was because it may have knocked things lose and clogged up the injector. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 9, 2010 Share Posted April 9, 2010 oh aight, and you dont want to run anything like fuel injector cleaner thru them? Link to comment Share on other sites More sharing options...
Baddog Posted April 9, 2010 Author Share Posted April 9, 2010 Would injector cleaner work differently then seafoam? And does the injector cleaner run through the gas tank? Link to comment Share on other sites More sharing options...
amp27 Posted April 10, 2010 Share Posted April 10, 2010 it it knock "it" loose then why stop. run a gallon thought it! Link to comment Share on other sites More sharing options...
papa g Posted April 10, 2010 Share Posted April 10, 2010 Your lifters should be hydraulic and not need adjustment. The valve lash should not change unless your lifter is failing. On your miss, you might need to change out that injector. If you disconnect injectors while the car is running and see if there is a change, if the idle does not change then that injector was not working. If you get a change in idle then that injector was fine. Sometimes you can take them out and clean them with carb cleaner. BE committed to DO what it takes to HAVE more of what you want in your life!!! Link to comment Share on other sites More sharing options...
Baddog Posted April 10, 2010 Author Share Posted April 10, 2010 How easy is it to take out the injector? Link to comment Share on other sites More sharing options...
kaz98gt Posted April 10, 2010 Share Posted April 10, 2010 Your lifters should be hydraulic and not need adjustment. The valve lash should not change unless your lifter is failing. On your miss, you might need to change out that injector. If you disconnect injectors while the car is running and see if there is a change, if the idle does not change then that injector was not working. If you get a change in idle then that injector was fine. Sometimes you can take them out and clean them with carb cleaner. There was a huge argument about this on another thread; some 2.2s are hydralauic prior to 97, some are after 97, and same with the 2.5. It's ridiculous; I know I have MLAs, and my 2.2 is from a 98. Easiest way is to check by popping the valve covers off, because only then you'll know what you're running. But yeah +1 how do you get an injector out? Link to comment Share on other sites More sharing options...
