Amberluvsblue07 Posted April 6, 2010 Share Posted April 6, 2010 Hey I just bought and changed out my accessory belt for a new one and im hear this squeaking noise like the belts either too tight or too loose is their a possibility that its just The other belt going bad? Link to comment Share on other sites More sharing options...
Platinum_Racing Posted April 6, 2010 Share Posted April 6, 2010 Is the belt on the pulley all the way? If its falling off the pulley it will make noise. The chances of the other belt starting to make noise right after a belt change are pretty slim. In fact, if the AC no longer works you might as well remove the belt like I did to regain some parasitic loss from the spinning AC clutch. The gain is extremely minor, but you might as well remove it if the AC stopped working and you're not looking into fixing it anytime soon. Also, belt tension should be set so that there is about 1 inch of belt deflection on the longest length of belt. Another good way to test belt tension is to twist the belt on its longest section. You should be able to just about rotate the belt 90 degrees to the pulleys. More than that and the belt is loose. Less than that and the belt is tight. Link to comment Share on other sites More sharing options...
Amberluvsblue07 Posted April 8, 2010 Author Share Posted April 8, 2010 Yes it is on there all the way. Its not a loud long screeching noise. It is an occasional minor squeak that dose not last longer than 15 sec. and only while im attempting any turn, but it dose not squeak every time I turn its only every now and then. and usually mostly after the first starup for the day. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted April 9, 2010 Share Posted April 9, 2010 Does it feel like the power steering kind of quits working mid turn? Link to comment Share on other sites More sharing options...
Amberluvsblue07 Posted April 10, 2010 Author Share Posted April 10, 2010 no my power steerings fine and the car has full fluid as well Link to comment Share on other sites More sharing options...
Legacy Wagon Posted April 13, 2010 Share Posted April 13, 2010 Mine used to do it when Florida got cold and I had just changed the belt, but it quit after the new belt wore in. Check and see if your alternator is adjusted tight enough. It may be bouncing. Other than that I dont really know why it would be doing that with a new belt unless it just hasnt been worn in yet. Sorry Link to comment Share on other sites More sharing options...
Amberluvsblue07 Posted April 14, 2010 Author Share Posted April 14, 2010 I think that that was it its been doing less and less since i bought it Link to comment Share on other sites More sharing options...
Legacy Wagon Posted April 14, 2010 Share Posted April 14, 2010 So it seems to be clearing up now? Link to comment Share on other sites More sharing options...
Amberluvsblue07 Posted April 15, 2010 Author Share Posted April 15, 2010 lol it was but now as its getting hotter it was worse today. what about a torque wrench do you think that would be any help? Link to comment Share on other sites More sharing options...
Legacy Wagon Posted April 15, 2010 Share Posted April 15, 2010 Can you determine which belt is squealing? Link to comment Share on other sites More sharing options...
Amberluvsblue07 Posted April 15, 2010 Author Share Posted April 15, 2010 yes its still the accessory belt Link to comment Share on other sites More sharing options...
Legacy Wagon Posted April 15, 2010 Share Posted April 15, 2010 Hmmm. Well, I figured it may just be breaking in. I suppose you tried the tension and made sure it was right. I can ask my friend Bryan. He's pretty good with stuff like this. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted April 15, 2010 Share Posted April 15, 2010 Here's what Bryan came up with: Could possibly be a pulley out of alignment. If the power steering pump or alternator is starting to go, it could momentarily cause excessive resistance that the belt can't hold and cause it to squeal for a moment. It's a possibility. If it seized up for a moment the belt wouldn't be able to grab. Link to comment Share on other sites More sharing options...
Amberluvsblue07 Posted April 15, 2010 Author Share Posted April 15, 2010 And how would i be able to tell if the pulley is outta alignment would it wobble or rotate crooked? also i know if the alternators bad what would happen eventually but if my power steering pump went bad then would the car drive with no power steering at all or what would the signs be? Link to comment Share on other sites More sharing options...
Legacy Wagon Posted April 16, 2010 Share Posted April 16, 2010 It would probably visibly wobble, but I'm not 100% as I've never had those do it. The crankshaft can do the same thing though if the key behind the pulley is damaged. You can see it wobbling around and it'll cut through the pulley. I'm assuming that would be the case. You can drive without power steering, but it is really uncomfortable at low speeds. I've never had a power steering pump go out on me, but I have had the system leak before and it usually will whine as you're turning. Not like a belt, but a different noise. Hard to describe. I know when my belt was loose the power steering would kick on out me mid turn...awkward. I would ask Platinum Racing though. That guy knows a crapload more than me. Link to comment Share on other sites More sharing options...
Amberluvsblue07 Posted April 16, 2010 Author Share Posted April 16, 2010 there is no wobbling it turned out to be a tightness problem I'm still trying to find the right adjustments for the belt all the power steering stuff turned out to be okay as well. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted April 19, 2010 Share Posted April 19, 2010 "Also, belt tension should be set so that there is about 1 inch of belt deflection on the longest length of belt. Another good way to test belt tension is to twist the belt on its longest section. You should be able to just about rotate the belt 90 degrees to the pulleys. More than that and the belt is loose. Less than that and the belt is tight." Then I would go by Platinum Racing's advice. Or are you looking for the positions to adjust each belt? Link to comment Share on other sites More sharing options...
