Tooshea Posted April 9, 2005 Share Posted April 9, 2005 and get better performance. I mean whats the real diff between the motors? It seems like no one really knows for sure. Is there someone that knows the whole story on this? Any help would be great. Link to comment Share on other sites More sharing options...
highwaydrifter Posted April 9, 2005 Share Posted April 9, 2005 turbo is diff, ecu is different, cams might be a bit diff, our intake is supposedly better and our intercooler is more efficent. Link to comment Share on other sites More sharing options...
GTWILLY Posted April 11, 2005 Share Posted April 11, 2005 The Sti Motor Has Forged Connecting Rods In It, So Its Stronger Than Ours, Thats Really The Only Thing Different Besides The Things Listed Earlier. Link to comment Share on other sites More sharing options...
rao Posted April 11, 2005 Share Posted April 11, 2005 Cams are the same, SHORT BLOCK (including the pistons, rods and crank) are the same. What is different is the configuration of the turbo outlet and the location of the throttle body. You would have to swap in the turbo, intercooler, intake manifold and throttle body. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
MDTURBO Posted April 11, 2005 Share Posted April 11, 2005 ehhh? it's the same 2.5 as far as I can tell. To answer you question directly, yes you can but you must change the turbo, the intercooler, and most likely make an adapter plate for the legacy throttle body to mount to the manifold. It's probably more trouble than it's worth. One can either wait for a FMIC or build your own. Then what turbo you use (stock vf40, or wrx-style vf22 or vf30) is irrelivant. 2012 Forester XT. Stage 2+ Retired from Racing. I used to build FMIC and more. Link to comment Share on other sites More sharing options...
highwaydrifter Posted April 11, 2005 Share Posted April 11, 2005 Cams are the same, SHORT BLOCK (including the pistons, rods and crank) are the same. What is different is the configuration of the turbo outlet and the location of the throttle body. You would have to swap in the turbo, intercooler, intake manifold and throttle body. Got alink about the cams part? From what i was told by a suby tech is that the cams are slightly different... Link to comment Share on other sites More sharing options...
KGreb Posted April 11, 2005 Share Posted April 11, 2005 No link, but Phil from Element Tuning did some measurements of Forester XT cams vs. STi cams in a post a while back on NASIOC. He measured them to be the same. From this data point most folks are of the belief that all the USDM turbo 2.5Ls have the same heads. Link to comment Share on other sites More sharing options...
jim malach Posted April 11, 2005 Share Posted April 11, 2005 no the pistons are diff 8.3 comp/ compared to 8.0......... Link to comment Share on other sites More sharing options...
KGreb Posted April 11, 2005 Share Posted April 11, 2005 LGT and STi are both 8.2:1 from the manuals I've seen. Link to comment Share on other sites More sharing options...
relhok Posted April 11, 2005 Share Posted April 11, 2005 no the pistons are diff 8.3 comp/ compared to 8.0......... Couldn't that small difference be accomplished with head gasket thickness? Could still be the same pistons. Link to comment Share on other sites More sharing options...
SUBE555 Posted April 12, 2005 Share Posted April 12, 2005 KGreb is on about that, the WRX STi, FXT, LGT, and Baja Turbo all have the same 8.2:1 CR. Link to comment Share on other sites More sharing options...
chucktoo Posted April 12, 2005 Share Posted April 12, 2005 Long blocks are the same. Just manifolds - TMIC - Turbo and tunnng are different. Link to comment Share on other sites More sharing options...
