maddoc Posted March 24, 2010 Share Posted March 24, 2010 So I didn't see any thread about this (I may be blind), but I wanted to compile all the rear sway bars for the Legacy. Mainly, I wanted pictures of each sway bar, and also wanted to compile which sway bars worked with what exhausts. For example, I have the Invidia Q300 Quad-tip exhaust (v1) and a Whiteline Adjustable rear sway bar. These don't work together. The sway bar comes into direct contact with the crossover piping. Now, I'm curious to see if there are sway bars that are designed differently to clear aftermarket exhausts like this. ** Reserved for pics - I'll post them once I get them** Link to comment Share on other sites More sharing options...
wcbjr Posted March 24, 2010 Share Posted March 24, 2010 How about you post what you want and narrow down our responses? That would make it a lot easier for us. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
maddoc Posted March 24, 2010 Author Share Posted March 24, 2010 How about you post what you want and narrow down our responses? That would make it a lot easier for us. I wanted to compile all the rear sway bars for the Legacy. Mainly, I wanted pictures of each sway bar, and also wanted to compile which sway bars worked with what exhausts. Um...post your rear sway bars and exhaust setups? I'm mainly trying to compile a database to determine rear sway bar designs and what will work well with different exhaust setups... As I mentioned, my Whiteline rear sway is in direct contact with my exhaust piping and is causing issues. So if there are other rear sway bars out there designed differently for the Legacy GT to alleviate this problem, I would like to know and compile a database of rear sway bars for other members to refer to. Was I not clear enough? Link to comment Share on other sites More sharing options...
wcbjr Posted March 24, 2010 Share Posted March 24, 2010 Nope, never did you state you wanted people to post their individual setups. You asked for a list. Anyways, SPT exhaust and Cusco rear sway, stock endlinks. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
subiedad51 Posted March 24, 2010 Share Posted March 24, 2010 Perrin catback and Perrin 22mm adj rear sways, energy bushings, avo stout mounts and perrin endlinks. Link to comment Share on other sites More sharing options...
Bolksey85 Posted March 24, 2010 Share Posted March 24, 2010 Perrin 22's F+R on Perrin mounts and bushings, Kartboy links, Magnaflow catback. No rubbing. Link to comment Share on other sites More sharing options...
GULLABLE0NE Posted March 25, 2010 Share Posted March 25, 2010 the new invidia quad tip dual exhaust works fine with perrin 22mm sways w/ rallitek hd endlinks Link to comment Share on other sites More sharing options...
bochinam Posted March 28, 2010 Share Posted March 28, 2010 Perring 25mm F+R, perring ends, mounts, clears Stromung exhaust. Link to comment Share on other sites More sharing options...
captainhook Posted April 1, 2010 Share Posted April 1, 2010 Perrin 22mm sways/brackets/endlinks + SPT CBE = no problems Perrin 22mm sways/brackets/endlinks + SPT CBE + Cobb springs = rubbing (see below) http://i660.photobucket.com/albums/uu325/tunedlgt/IMG_1130-1.jpg They clank together over bumps. http://i660.photobucket.com/albums/uu325/tunedlgt/CleanedPadded.jpg Cheap easy fix. (Radiator hose + zip ties) Link to comment Share on other sites More sharing options...
Kylar Posted April 2, 2010 Share Posted April 2, 2010 Perrin 22mm sways, Perrin stout mounts, stock endlinks (for now), and x02 racing exhaust. Clears, no issues! Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 2, 2010 Share Posted April 2, 2010 whiteline front sway, avo rear sway, avo reinforcement mounts, group a endlinks with modified borla catback and rallitek springs. had an issue of rubbing/vibrating after i had cut the 2.5" piping out to replace with 3" piping but had it dealt with Link to comment Share on other sites More sharing options...
Strizzy Posted April 5, 2010 Share Posted April 5, 2010 Cobb front and rear swaybars with stock endlinks. X02 exhaust. No issues. My bad luck build Link to comment Share on other sites More sharing options...
EquinnoxX Posted April 7, 2010 Share Posted April 7, 2010 Zero / Sports F+R Sways w/ Fujitsubo exhaust. They fit fine, no issues. Sorry this is the best pic I have of them: http://farm4.static.flickr.com/3102/3142315136_c48b804b5c.jpg Link to comment Share on other sites More sharing options...
captainhook Posted April 7, 2010 Share Posted April 7, 2010 /\ still on stock springs? Link to comment Share on other sites More sharing options...
EquinnoxX Posted April 8, 2010 Share Posted April 8, 2010 ^^ Yesh. Link to comment Share on other sites More sharing options...
captainhook Posted April 8, 2010 Share Posted April 8, 2010 If you plan on adding springs, I would try to find someone with a similar setup that has already tried it to avoid the issue I ran into. Link to comment Share on other sites More sharing options...
EquinnoxX Posted April 15, 2010 Share Posted April 15, 2010 ^Good point. I did have sti pinks installed but have since gone back to stock. I didn't notice/hear any rubbing but I didn't really check. I'll have to look under the car the next time I clean it. Link to comment Share on other sites More sharing options...
sxspete Posted April 16, 2010 Share Posted April 16, 2010 XO2 axle back,AVO rear bar,AVO HD reinforcements, on third set of end links(now Rallitek). Still getting loud clicking with suspension contact. Link to comment Share on other sites More sharing options...
TSiWRX Posted May 5, 2010 Share Posted May 5, 2010 Cross-referencing: http://legacygt.com/forums/showthread.php/invidia-q300-exhaust-rear-sway-bar-problem-134456.html <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
wcbjr Posted May 6, 2010 Share Posted May 6, 2010 Just an FYI, I found out yesterday that the Rallitek rear endlinks are shorter than stock. This has the side-effect of pulling the ends of the bar lower and raising the bar itself up and away from the exhaust pipes underneath. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
TSiWRX Posted May 6, 2010 Share Posted May 6, 2010 ^ Yep. Rallitek, at one point (still?) bill(s/ed) those as being well-suited for slightly-dropped BL/BPs. The AVO bracket reinforcements, as Gmachine mentioned in another thread, also displaces the bar a little bit further back (i.e. by the plate's thickness) towards the rear of the vehicle, too. But here, the caveat is that it may or may not bring the bottom corners of the plate and/or the mounting bracket/hardware into contact with the cat-back piping. --- As a side-note, I was surprised at how easily the Rallitek HD rears - which, like you said, are noticeably shorter than the stock pieces - installed, particularly as I had my car on jackstands (while I have a set of Raceramps, I decided to jackstand and take the wheels off for this install, as I timed it to coincide with my winter-to-summer switch-over, anyway ). I'd fully expected to have to jack the individual suspension a bit, but they got into position without any issues. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
