valerka Posted March 17, 2010 Share Posted March 17, 2010 As I know the gearing in 6MT and 5MT are of different value, and I also know that LGT 5MT can reach 60mph in 2nd gear with still a little room to spare. My question is, can the Spec B do the same, or would one need to engage the 3rd to reach 60? Link to comment Share on other sites More sharing options...
integroid Posted March 17, 2010 Share Posted March 17, 2010 I think I can reach 60 in my 6mt but I can rev to 8K rpm. Link to comment Share on other sites More sharing options...
TheHolyGhost Posted March 17, 2010 Share Posted March 17, 2010 AFAIK you'll need 3rd gear to reach sixty without your rev limiter removed. Link to comment Share on other sites More sharing options...
fishbone Posted March 17, 2010 Share Posted March 17, 2010 There is no point in winding it out that high either, especially on the stock turbo. There is nothing left up there. Link to comment Share on other sites More sharing options...
m sprank Posted March 17, 2010 Share Posted March 17, 2010 55 in second need to shift to make 60mph. 55 in second, 85 in third, 110 in fourth. This is what you will hit at 6700 RPM. Even with the extra shift I can nail 0-60 in about 4 flat. With a good clutch I bet I can get 4 all day. Link to comment Share on other sites More sharing options...
integroid Posted March 17, 2010 Share Posted March 17, 2010 There is no point in winding it out that high either, especially on the stock turbo. There is nothing left up there. I completely agree on a stock motor and stock turbo but I have ported/built heads with cams so I still have a lot left over up to 8K Link to comment Share on other sites More sharing options...
valerka Posted March 17, 2010 Author Share Posted March 17, 2010 Quite interesting information guys, Thanks! so if you are not a pro in MT then you would be pulling better times 0 to 60 with 5MT in comparison to the 6MT. What about hwy cruising how much lower the RPMs run at 65-70 mph in final gear of the 6MT comparing to 5MT, and does it translate in to substantial fuel savings? Link to comment Share on other sites More sharing options...
m sprank Posted March 18, 2010 Share Posted March 18, 2010 The 6MT in the SpecB has different final drive ratios than the 6MT in the STi. The SpecB 6MT is specifically geared for better fuel economy is 6th. Yes, 5MT's can be a little easier to pull good 0-60 times. But, the 5MT is not as strong as the 6MT. 6MT holds more power. Link to comment Share on other sites More sharing options...
Guest Posted March 18, 2010 Share Posted March 18, 2010 The 6MT in the SpecB has different final drive ratios than the 6MT in the STi. The SpecB 6MT is specifically geared for better fuel economy is 6th. Not true. Same final drive ratio between all years STI and SpecB 6MT (3.9:1). Same 1-4 gear ratios as 07-10 STI. The only difference are 5 & 6th ratios that are taller than STI's one. Link to comment Share on other sites More sharing options...
m sprank Posted March 18, 2010 Share Posted March 18, 2010 My bad. Thanks unclemat. It is not the "final" drive ratio, but the 5/6 ratios that are different. I am seeing STi owners swapping to SpecB 6MT's for fuel economy. Link to comment Share on other sites More sharing options...
Guest Posted March 18, 2010 Share Posted March 18, 2010 My bad. Thanks unclemat. It is not the "final" drive ratio, but the 5/6 ratios that are different. I am seeing STi owners swapping to SpecB 6MT's for fuel economy. Well, yeah, I replaced 5&6 gears in my 08 STI tranny with JDM Forester STI gears - same ratio as SpecB, but the gears are different (different size keyways). For an STI owner it would be stupid to replace entire tranny with SpecB tranny and lose front LSD and DCCD. Link to comment Share on other sites More sharing options...
m sprank Posted March 18, 2010 Share Posted March 18, 2010 I know the LSD swaps (I am looking into it). Not sure about the DCCD. But it would seem easier to install the needed gears over swapping all the other stuff. unclemat, you are using an STi front LSD, no? Link to comment Share on other sites More sharing options...
Guest Posted March 18, 2010 Share Posted March 18, 2010 I know the LSD swaps (I am looking into it). Not sure about the DCCD. But it would seem easier to install the needed gears over swapping all the other stuff. unclemat, you are using an STi front LSD, no? Yes, in both 08 STI gearbox and 08 SpecB gearbox. I replaced the SpecB one with the STI one, and I am going to install the SpecB one in my 2nd wagon. DCCD is nice but I'd rather have front LSD than DCCD. Link to comment Share on other sites More sharing options...
m sprank Posted March 18, 2010 Share Posted March 18, 2010 I agree, front LSD should change the entire handling characteristics of the car. I am deeply contemplating grabbing a used LSD and installing in my SpecB. Glad to hear it is working for you. Link to comment Share on other sites More sharing options...
