fredraud Posted February 26, 2010 Share Posted February 26, 2010 My Sister's 2000 LGT Had sat for 2 years due to a blown head gasket. What she didn't tell me was how hot and how many times she got it hot. When she bought the car, it smelled of coolant. She took it back to the dealer she bought it from, and they "fixed it". Then the heater core exploded. They replaced it. Then the rad exploded, they fixed that. Then it started to piss collant from between the head and block on cylinder 1. Then it sat for 2 years. My brother in law, drove out east and brought it out here 6400km trip. I pulled the engine, drained the oil and found chocolate milk.... 6 liters of it. When i pulled of the heads, i found 1/4" thick coating of grey crap on all the coolant passages. The dealer must have run a nice mix of 50% block sealer and 50% antifreeze!!. I decided i would split the block to check out the pistons and bearings. What i found was the rod bearings were down to copper, and the pistons looked like they had been dragged down a gravel road. Specs. EJ252 block and sohc heads 12:1 TWE pistonsSTI Rodscometic head gasketsnitrated crankTWE cams and springs (only on the intake) with titanium lash caps10mm STI oil pumpPorted headsACL race bearingsBlock and heads CBM decked. & bored .020 overNow the root cause. I found when i first fired it it would not rev pass 3500. missed bucked ect. I tested the fuel pressure and found that it was at 43psi until i hit the gas, then it dropped. When i pulled the rear seat out, i found that someone had tried to fix a booboo they did (breaking off the elbow for the supply line off the top of the unit) by using 1/8 brake line and hot glue!!! So running lean casued HG failure and the dealer tried to bandaid from there on in. New $300 pump/sender assembly from subaru, and things ran magical!!! Old parts new parts Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 28, 2010 Share Posted February 28, 2010 WOW! That is gonna be a happy EJ when you finish Link to comment Share on other sites More sharing options...
fredraud Posted May 15, 2010 Author Share Posted May 15, 2010 Update. The Car runs freaking awsome!! Handed it back to my sister last week, but not before i beat on it some to ensure nothing was gonna break. It averages 30-31mpg on the highway at 70mph and pulls hard from 2000-redline.[ame=http://www.youtube.com/watch?v=TEvVssfg4UI]YouTube- test run with new engine[/ame] is a video of the first test flight I would like to give a huge thanks to Tom Penner at TWE for putting up with me and taking the time to answer my questions. The components he sells may seem at first to be priced high, but man do they work!! I wish i would have gone this route with the forester engine build. Link to comment Share on other sites More sharing options...
N.sane Posted May 16, 2010 Share Posted May 16, 2010 Wow, good stuff. I wish I had the knowledge to do all that. Props to you! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 17, 2010 Share Posted May 17, 2010 all you need now is to slap a VF 46 on there:lol: the parts looked great and better spend a little more now than to have to spend the exact same amount 20k miles from now. Wiseco pistons FTW Link to comment Share on other sites More sharing options...
fredraud Posted May 17, 2010 Author Share Posted May 17, 2010 With 12:1 could prob run err 2-5lbs with e85 lol Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 17, 2010 Share Posted May 17, 2010 With 12:1 could prob run err 2-5lbs with e85 lol 12:1 plus 3 psi plus e85 I would venture to say 190-200 at the wheels hopefully Link to comment Share on other sites More sharing options...
