Mindspin311 Posted April 20, 2010 Share Posted April 20, 2010 Sent a PM as well Link to comment Share on other sites More sharing options...
GrimmSpeed Posted April 22, 2010 Share Posted April 22, 2010 Everyone that PM'd us should have gotten their new bracket shipped out today. If you sent us a PM and did not receive a response please let us know! Mike Link to comment Share on other sites More sharing options...
Legend Posted April 27, 2010 Share Posted April 27, 2010 ^^ Thanks GS. New bracket looks very nice. Haven't tried fitment yet. I'll finally be installing the bcs this week. One thing I'm not clear on... Will I need to pick up extra vacuum tubing or is there enough tubing with the stock setup to re-use? Seems like I'd need to add some... My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
Legend Posted April 29, 2010 Share Posted April 29, 2010 One thing I'm not clear on... Will I need to pick up extra vacuum tubing or is there enough tubing with the stock setup to re-use? Seems like I'd need to add some... For the intake port, re-use a piece from the stock system. For the other two ports, pick up 3-feet of 5/32" vacuum tubing (also called windshield wiper hose). Identical material, ID, and OD as the stock hose. Cost $3.36 after tax at NAPA. For those lines I ran 15" of tubing under the intake and ended up trimming an inch or two for final fitment. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
jaxx4k Posted January 15, 2011 Share Posted January 15, 2011 so add this EBCS & a boost controller? Link to comment Share on other sites More sharing options...
Legend Posted January 15, 2011 Share Posted January 15, 2011 so add this EBCS & a boost controller? sentence fragment. This is a boost controller (EBCS). My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
SpecBGuy Posted January 15, 2011 Share Posted January 15, 2011 dont mess with RAZOR RAMON CHICO Link to comment Share on other sites More sharing options...
jaxx4k Posted January 16, 2011 Share Posted January 16, 2011 how this EBCS compare to a MBS? Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted January 17, 2011 Share Posted January 17, 2011 manual boost controller is different. it is not computer controlled On the search for a new DD... Link to comment Share on other sites More sharing options...
Nickz31se-r Posted April 13, 2011 Share Posted April 13, 2011 Thanks much Link to comment Share on other sites More sharing options...
GrimmSpeed Posted April 18, 2011 Share Posted April 18, 2011 You could always run the Hybrid setup...MBC + BCS Justin Grimm Link to comment Share on other sites More sharing options...
gstreev Posted June 14, 2011 Share Posted June 14, 2011 You could always run the Hybrid setup...MBC + BCS Justin Grimm How do you adjust the amount of boost on this, is there a knob or screw? Link to comment Share on other sites More sharing options...
GrimmSpeed Posted June 14, 2011 Share Posted June 14, 2011 Yeah, Actually similar to the BCS set up you will want to get a tune for the set up, basically it uses BOTH devices together to regulate boost in the most efficient and effective manner. And yes, small adjustments CAN be made to full throttle boost via the MBC however we STRONGLY suggest contacting a tuner for any changes! Will Link to comment Share on other sites More sharing options...
gstreev Posted June 15, 2011 Share Posted June 15, 2011 Yeah, Actually similar to the BCS set up you will want to get a tune for the set up, basically it uses BOTH devices together to regulate boost in the most efficient and effective manner. And yes, small adjustments CAN be made to full throttle boost via the MBC however we STRONGLY suggest contacting a tuner for any changes! Will I have an older Cobb Access port, could I download a map for this device, car is otherwise stock? Assuming I get a tune, how much boost will the car be at if I install it with no other adjustments. I'm still not clear if I can adjust boost with this or install another MBC? Sorry, I'm new to this. Link to comment Share on other sites More sharing options...
GrimmSpeed Posted June 15, 2011 Share Posted June 15, 2011 Hey man not a problem, the set up itself is not the simplest thing for sure. You cannot adjust boost via your accessport unless you have the software beyond just the unit that lets you tune the vehicle, i.e. protune it. The unit off the shelf cannot be used to tune the vehicle to what the BCS needs. This device lets you control boost to any level you want it set at, so there is no preset boost level. Am I helping or hurting haha? Will Link to comment Share on other sites More sharing options...
kongzilla Posted June 15, 2011 Share Posted June 15, 2011 Your haunting him. Link to comment Share on other sites More sharing options...
